H22 oil pan torque spec?
Old Jun 26, 2003 | 12:29 PM
overdose's Avatar
Default H22 oil pan torque spec?
what's torque spec for the bolts, i hear this is important?
swapping my pan gasket tonight
Old Jun 26, 2003 | 12:49 PM
Behan's Avatar
Default Re: H22 oil pan torque spec? (overdose)
the oil pan bolts get torqued to 108 ft lbs and yes it is very important that you use the correct torque specs.
when you tighten the bolts you must do so in this sequence. the block of numbers below represent the bolt pattern of the oil pan. basically you start in the center and tighten in a criss cross type pattern.
15, 13, 7, 5---------------- 1, 3, 9, 11, 17
18, 12, 10, 4----------------2, 6, 8, 14, 16
here is the website i pulled the information from. The tightening pattern is on page 22.
http://www.icelord.net/honda/r...r.pdf
Old Jun 26, 2003 | 12:52 PM
overdose's Avatar
Default Re: H22 oil pan torque spec? (93preludevtec)
so just tighten by number sequence in your above diagram?
1,2,3 and so on?
Old Jun 26, 2003 | 12:54 PM
Behan's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by overdose &raquo;</TD></TR><TR><TD CLASS="quote">so just tighten by number sequence in your above diagram?
1,2,3 and so on?</TD></TR></TABLE>
yes. i also just edited my post and included the website i pulled this info from. here is they're home page. its for a 4th gen.
http://www.icelord.net/honda/repair/
Rhood
Feb 7, 2007 05:30 PM
DjTrex
Sep 24, 2005 01:40 PM
lsvtec101
May 20, 2005 05:21 PM
hugh_jazz_sponer
Aug 5, 2004 12:54 PM
JDubya
Jun 9, 2004 03:11 PM
