dual tip si exhaust or single tip?
some guy wants to trade me his apexi n1 exhaust with 4inch pipe from cat to the canister from his si for a si stock exhust and i was just wonderin if the si stock exhaust is a single tip exhaust or is it a dual tip exhaust and would it make a difference if he had a single or dual?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91civicDXdude »</TD></TR><TR><TD CLASS="quote">NO YOU DONT WANT BACKPRESSURE.
jesus when will this myth die.
do a websearch for "exhaust gas velocity" or "delta pressure"
back pressure is resistance and is always bad.</TD></TR></TABLE>
Exactly, what people dont understand is that you cant make the exhaust too big, the velocity then drops too low. People that say "you need backpressure" probably put 3" piping on their stock D series. You will lose power that way. The optimal exhaust will have just enough diameter to flow with no backpressure.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hcivic88 »</TD></TR><TR><TD CLASS="quote">most stock Si's had single exhaust back to the muffler. then two tips exiting the muffler. DX's had single all the way</TD></TR></TABLE>
Yep
Yep
brandonb18
31
Nov 22, 2009 09:13 AM
johnRsX05
Jan 4, 2005 07:13 PM
