Toda spec C idle
Old Jun 26, 2003 | 08:36 AM
EF_LSVtec's Avatar
Default Toda spec C idle
Idle is not as steady as my CTR's...is this normal? I tried raising the idle a bit to 1200 and it's at least manageable. I noticed too that sometimes the idle is steady between 800-900 rpm but sometimes after hard driving, tach goes below 500 and immediately dies. Driving to work this morning especially through heavy traffic is not fun. Heel and toe is slightly difficult especially if you have the gas pedal slightly higher than usual...
Old Jun 26, 2003 | 10:12 AM
xJ.SLOTHx's Avatar
Default Re: Toda spec C idle (EF_LSVtec)
whats up man...long time no talk. i was wondering if you were running a stock LS timing belt with those Spec C's?
Old Jun 26, 2003 | 10:13 AM
NSX Bob's Avatar
New User
C's (and B's) primaries are almost as big as the CTR's vtec lobe. You need good tuning to get them to idle correctly. My B's idle almost like stock, although they sound a hell of a lot different .
Old Jun 26, 2003 | 10:23 AM
EF_LSVtec's Avatar
Default Re: Toda spec C idle (ian)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ian &raquo;</TD></TR><TR><TD CLASS="quote">. i was wondering if you were running a stock LS timing belt with those Spec C's?</TD></TR></TABLE> I'm doing pretty good Ian. Chad sent me some info about the upcoming carshow down there...I'm busy autoXing and fixing my car, so i can't really commit. About your Q, Yes I am...but I'm thinking of getting the ones made by Toda in a month or so. I've heard mixed info about that too, but just to be on the safe side. My timing belt is pretty new anyway and i dont think a balanced motor would cause the timing belt to snap even on high rpm's.
Old Jun 26, 2003 | 11:46 AM
-Racer X-
Guest
Posts: n/a
hmmm, what about the JUNs, peopel say they idle like stock, hows the vtec lobe on em?
Old Jun 26, 2003 | 11:53 AM
b19coupe's Avatar
Toda B, C, and D's are a little trickier to get to idle correctly-this is normal, due to the bigger non-VTEC lobes. And upgrade your timing belt ASAP, I have heard too many stories of stock belts shredding teeth, even relatively new stock belts.
Old Jun 26, 2003 | 12:01 PM
EF_LSVtec's Avatar
Default Re: Toda spec C idle (b19coupe)
I hear ya on the belts...only thing is I'm using LS waterpump etc and I wonder if Toda makes one for the LS block...otherwise I have to get one for the B18C and have to upgrade all pumps to make it work.
Old Jun 26, 2003 | 01:22 PM
b19coupe's Avatar
Just the water pump. The oil pump is driven directly by the crank.
Modified by b19coupe at 4:19 AM 6/27/2003
Old Jun 26, 2003 | 07:37 PM
powerfulperformance's Avatar
I got toda c and they idle like stock. Get a good tuner....
Old Jun 26, 2003 | 07:47 PM
EF_LSVtec's Avatar
Default Re: (powerfulperformance)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by powerfulperformance &raquo;</TD></TR><TR><TD CLASS="quote">I got toda c and they idle like stock. Get a good tuner....</TD></TR></TABLE> I wonder if its because I'm running non0bd? I'm getting my car tuned tomorrow if I have time or maybe Monday. Someone local is offering me a set of extrude-honed skunk2 intake and he said would give me at least 5whp...I doubt it though, but if he can back it up with dyno results, I'll take it.
Old Jun 27, 2003 | 11:16 AM
EF_LSVtec's Avatar
Default Re: (EF_LSVtec)
found out last night that my distributor igniter's going bad...reason for the fluctuating idle (i think). I'm getting another distributor this afternoon and will find out if it fixes my problem.
*I can simply replace my igniter too, but long story (for the inquiring minds)
Old Jun 27, 2003 | 11:49 PM
blykins's Avatar
Banned
I have toda B's, it idles like a v8. Its cool.
Old Jun 28, 2003 | 05:29 PM
joe_bocc's Avatar
Default Re: Toda spec C idle (-Racer X-)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote"> hmmm, what about the JUNs, peopel say they idle like stock, hows the vtec lobe on em? </TD></TR></TABLE>
The VTEC lobe won't affect the idle of an engine, the primary/non-VTEC lobe will. When you compare the Toda B/C and JUN lll primary lobes you will understand why the Toda cams have lumpy idle. The Toda cams have 11 mm lift on the primary lobe while the JUN lll cams have 9 mm list max.
Black R
11
Aug 11, 2005 12:44 PM
Black R
May 14, 2002 11:59 AM
TaboR
Apr 9, 2002 12:52 PM
1fastGSR
Dec 26, 2001 04:52 PM
itr501
Sep 27, 2001 04:01 PM
