damn check engine light at highway speeds
Old Jun 26, 2003 | 08:30 AM
.Noah Fecks's Avatar
Default damn check engine light at highway speeds
ok so i was throwing a few codes a while back and i got everything cleared up. but now when i get going about 70-75 on the interstate the check engine light comes on and it throw the VSS code. wtf is it doing this. its working perfectly. i dissconnected the cable once to clean out my guages but i connected it back. it works. i just want to know why my light comes on if it works. anyone else ever have this problem?
Old Jun 26, 2003 | 09:41 AM
raene's Avatar
Default Re: damn check engine light at highway speeds (Noah *****)
The speedo in the cluster is mechanically driven. The VSS is a mechanically-driven electrical unit that sends pulses, with the # of pulses sent per time unit dependent on speed, to the ECU. If the VSS sending unit it malfunctioning you won't see a problem with the speedo like you would with an electrical unit in the transmission. Right now I'd expect that your ECU isn't seeing the VSS output; as far as it knows you're free-revving the car in your garage. It has no other way to know the car's moving except when you coast down in gear, and that's usually where you'll throw a VSS code (though sometimes the ECU will figure it out under high-load conditions, like WOT).
Try another gauge cluster!
Old Jun 26, 2003 | 10:01 AM
Default Re: damn check engine light at highway speeds (raene)
i know that the gas guage doesnt work properly, and now this. i guess ill start looking for an SI cluster. do you know if its plug and play? i have an std
Old Jun 26, 2003 | 10:24 AM
raene's Avatar
Get one from the same year and it should be... I'm not 100% on that though.
I know we plugged an Si '89 cluster into an '88 STD and it worked fine, except we had a similar problem with the VSS on the Si cluster, so we swapped back
Old Jun 26, 2003 | 10:28 AM
damnit. well ill try to find one. i hope they dont try to charge me an arm and a leg. btw what redline would i have if i get a tach? like 5?
Old Jun 26, 2003 | 11:04 AM
raene's Avatar
*shrugs* Tach just indicates the rpm, doesn't dictate your redline Your ECU will dictate that. I'm not sure what an STD can go up to, though!
Old Jun 26, 2003 | 11:07 AM
i know the ecu determins it. but i dont wanna redline it intentionally to find out what it is. ill look like a fool...
Old Jun 26, 2003 | 11:21 AM
raene's Avatar
Why? Unless you can find the specs, that's really the only way to tell!
Tank_EM2
Honda Civic (2001 - 2005)
Jul 1, 2014 03:28 PM
steelrainwarrior
14
Nov 5, 2006 05:41 PM
JustinG60
Mar 30, 2005 08:29 PM
2ndGenREX
Mar 18, 2005 02:03 PM
c.dub
Mar 6, 2005 08:49 PM
