compression
Old Jun 26, 2003 | 08:11 AM
slowassgsxr750's Avatar
Default compression
is it true that b18c has a higher deck then b18a/b?so if i ran gsr internals in a ls block,how many points will the compression will be raise over stock gsr?
Old Jun 26, 2003 | 08:26 AM
Pacman
Guest
Posts: n/a
Default Re: compression (singleslamrex)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by singleslamrex &raquo;</TD></TR><TR><TD CLASS="quote">is it true that b18c has a higher deck then b18a/b?so if i ran gsr internals in a ls block,how many points will the compression will be raise over stock gsr?</TD></TR></TABLE>
Nope. The deck height it is the same thing.. The only different thing is the stroke. So if you want to put a GSR crank must use GSR rod and pistons. The points are going to stay the same. The only Deck height differents is the b16 motor..
Old Jun 26, 2003 | 09:49 AM
Default Re: compression (Pacman)
so it will be just like a stock gsr block without the oil squirters?
Old Jun 26, 2003 | 10:28 AM
Pacman
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by singleslamrex &raquo;</TD></TR><TR><TD CLASS="quote">so it will be just like a stock gsr block without the oil squirters?</TD></TR></TABLE>
YES, that's it
Old Jun 26, 2003 | 11:58 AM
b19coupe's Avatar
Without the squirters, and without VTEC pressure to the head, unless you run an external oil line. You probably knew this.
bustdgst
Jan 25, 2007 09:54 PM
98h22
Feb 26, 2006 06:50 PM
HONDA RR
Jul 3, 2005 11:31 PM
dunkd
Aug 29, 2004 12:29 AM
slowassgsxr750
Jun 26, 2003 09:41 AM
