remove power steering belt
Old Jul 25, 2001 | 06:22 PM
ITR164's Avatar
New User
Default remove power steering belt
Hi,
It can be a stupid question. I couldn't find it in the search.
Can someone give me a brief (detail if possible) as to how I can
remove the steering belt?
thanks
Old Jul 25, 2001 | 06:28 PM
b00st-0wnz's Avatar
From: Drinking Beer in sunny FL and jamming to Skid Row, USA
Default Re: remove power steering belt (ITR164)
It's easy.
On the back side of the pump where it attaches to the power steering pump bracket is a bolt.. 14mm I think, it's torqued to 17lbs-ft, loosen it. Then go to the wing nut at the top, turn it COUNTER-clockwise to loosen, clockwise to tighten, while turning the wingnut make sure the belt is becoming less tense (less tensioned? hehe) just to make sure I'm not backwards . Eventually the belt will be loose enough to remove. Once it's off, just tighten down that bolt you loosen earlier so the pump doesn't move around.
Old Jul 25, 2001 | 07:03 PM
JohnnyBoy's Avatar
Default Re: remove power steering belt (Dave-ROR)
http://216.149.197.219/dscr/ubb/Forum7/HTML/000428.html
Old Jul 25, 2001 | 07:22 PM
Willard's Avatar
12mm maybe.... me thinks
Willis
Old Jul 25, 2001 | 09:34 PM
t's Avatar
t
Default Re: remove power steering belt (Willard)
You are correct sir 12mm
Old Jun 17, 2003 | 12:27 PM
TypeR 01 886's Avatar
Default Re: remove power steering belt (t)
Are there any drawbacks to doing this. Like not using the pump for a little while... wil it hurt and thing... can I put the belt back on 1,2,3 and have power steering again?!? little more info pleeeez
Old Jun 17, 2003 | 12:28 PM
Willard's Avatar
Default Re: remove power steering belt (TypeR 01 886)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TypeR 01 886 &raquo;</TD></TR><TR><TD CLASS="quote">can I put the belt back on 1,2,3 and have power steering again?!?</TD></TR></TABLE>
Yes.
Old Jun 17, 2003 | 12:30 PM
Chris N's Avatar
It takes 5 minutes max to put the belt on or take it off.
Note - it is not worth it to take the belt off and do nothing else, except for drag. It makes turning the wheel VERY VERY difficult for street driving. Much more difficult to drive than a manual rack.
Allowing the PS fluid to loop through the rack is much much more effective, like how Dropspeed did it (and others).
Old Jun 17, 2003 | 12:39 PM
Default Re: remove power steering belt (Chris N)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chris N &raquo;</TD></TR><TR><TD CLASS="quote">
Allowing the PS fluid to loop through the rack is much much more effective, like how Dropspeed did it (and others).</TD></TR></TABLE>
Do you have a link to the thread or procedure.
Old Jun 17, 2003 | 12:51 PM
Chris N's Avatar
Search Dropspeed's archived topics in the R forum. You'll see the thread on making a manual steering rack.
Old Jun 17, 2003 | 02:56 PM
Tweakmeister's Avatar
http://www.hogens.com/car/defa...x.php
Old Jun 17, 2003 | 04:38 PM
98typer794's Avatar
there's actually 2 12mm bolts to loosen, its very easy, as they said
Old Jun 17, 2003 | 05:33 PM
canuckr's Avatar
Do you have a link to the thread or procedure.</TD></TR></TABLE>
https://honda-tech.com/zerothread?id=184202
I took my belt off last year to see what it was like. Overall I like it alot, if anything it will help make your arms stronger . Since I took the belt I have been meaning to take the whole pump out, but lazyness ownz me big time.
Old Jun 17, 2003 | 05:40 PM
euclid's Avatar
Default Re: remove power steering belt (canuckr)
take itout, have no fear, the only tough part is under 2mph, but it's still manageable, the feel on the road is 10x better... then just loop the lines later and get more improvment.
penultimeta
May 23, 2010 03:31 PM
deemee
Jul 24, 2009 02:19 PM
ZakkWylde
May 21, 2007 12:45 PM
digitalh3lix
Dec 13, 2004 01:11 PM
done
May 12, 2002 11:45 AM
