WOW!!! Finally thought I'd share!!
Old Jun 26, 2003 | 07:24 AM
SloCivicHMM's Avatar
Default WOW!!! Finally thought I'd share!!
AFter deciding on what to do since January, and deciding this and that then this, then the whole "what tire" ordeal I finally got them in!!! Yes ladies and Gentlemen, My TEINS are in!!! wOOOt!!
The install went pretty simple, it was divided into 2 days after work, first rear then the front. Parts added, SRR LCA's and TEIN SS coilovers My Suspension is one big step closer to being complete!!
Current Set up: 92 HATCH VX (DOHC ZC MOTOR)
Brakes : OE Front with slotted/drill rotors, Teg Rear disc conversion with OE rotors, Axxis Metal Master pads all around, and Goodridge SS brake lines.
Suspension : Tein SS coilovers, SRR rear LCA's, ITR rear upper strut bar, 00 Si front upper Strut bar, DIY trunk bar, and Progress camber kit front/rear.
Soon to come: Benen rear lower tie bar, ITR rear sway, and still decided on front brake set up most likely OEM from a bigger brother.....
PICTURES http://photos.yahoo.com/slowcivichmm go to the MY **** folder.
THANKS TO Johnn @ http://www.jaydm.com and fellow HT member Ghettoracer for parts and my Clubsi friends for putting up with my "what about these", or this or that posts and or questions...
sanjiyan69
Jan 27, 2014 05:21 PM
Mr. EG
Suspension & Brakes
40
May 3, 2012 03:23 AM
viskii420
Suspension & Brakes
Mar 13, 2006 10:10 AM
99SlammedCivic
Aug 23, 2004 07:01 PM
