d15b7-mini-me vs. d16z6 D-SERIES!
Old Jun 26, 2003 | 02:23 AM
jdmsiR20's Avatar
Default d15b7-mini-me vs. d16z6 D-SERIES!
to the mods, not sure where this would go, but it seems like EG+ CIVIC forum rocks!... move if necessary..
well i'm hoping this thread becomes mainly tech.... both motors are sohc vtec, stock (or as stock as possible)...
but of course the d15mini me setup will vary, lets say with the z6head and manifold (y8 discussion later)... which motor seems to be the best of choice?
mini me cr is approx 10.1, with the d16z6 at approx 9.1
which motor is overall better, in terms of strength/reliability? the rods on the d15 are known not to be the best, yet it does have a pretty good r/s ratio... i've also heard of cooling problems with it...then again, i could just buy a d16 and throw it in, but where would be the fun? i'm really split on it, as d16's seem to go for more expensive nowadays, and a d15mini me can be had for a little bit cheaper.....
any one of these motors will be going into my 92 dx hatchie and i'm definitely interested in what everybody has to say
oh yeah, anybody have these motors for cheap? ha! even one blown, i'll take it, just lookin to gain experience on... thanks all!
Old Jun 26, 2003 | 04:15 AM
EVIL Hx Coupe's Avatar
Default Re: d15b7-mini-me vs. d16z6 D-SERIES! (jdmsiR20)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">the rods on the d15 are known not to be the best, cooling problems with it </TD></TR></TABLE>
I'm pretty sure the D16Z6 will be more realiable...
Old Jun 26, 2003 | 04:19 AM
sohc_boy's Avatar
Default Re: d15b7-mini-me vs. d16z6 D-SERIES! (EVIL Hx Coupe)
u could also go with the 1.5 jdm sohc vtec motor which puts out pretty much the same power as the z6 and an lsd to boot. that would retain your reliability since it is a stock honda motor not a hybrid mini-me.
Old Jun 26, 2003 | 05:43 AM
Zer0DazE's Avatar
stick the head on the b7 and drive it around while you collect the parts to build a high compression d16
see my sig for pistons, and blocks are a dime a dozen.
Old Jun 26, 2003 | 01:42 PM
jdmsiR20's Avatar
Default Re: d15b7-mini-me vs. d16z6 D-SERIES! (Zer0DazE)
ttt
Old Jun 26, 2003 | 01:49 PM
BauleyCivic's Avatar
Risky Business
i'm going mini me with my d15b7...and the CR will be approx 11:1 with a y8 head gasket...i picked up a p28 and z6 head for about $300 total, and then it will be another 200 for head gasket, plug wires, plugs, water pump, timing belt, etc...i am going to be doing the swap next week and there will be a large tech post in this forum about how it went...but according to the site below the mini me with y8 gasket will yield 135 HP and an 11:1 CR...i am hoping for high 15's with this setup...also you can add zc pistons and raise the compression another half point...so my vote will go for the mini me because i can replace key components (head gasket/timing belt/plug wires), gain 10 HP, and save a few hundred bucks
http://www.iapecc.com/mini_me.htm &lt;--- VERY useful mini me site
Old Jun 26, 2003 | 02:52 PM
tonesdef's Avatar
Default Re: d15b7-mini-me vs. d16z6 D-SERIES! (BauleyCivic)
stick with the d16z6 i went the mini me d15b7 route and the car wasn't that much faster and i threw a rod. With the d16 i'm running a 15.5 and its more reliable.
Old Jun 26, 2003 | 03:41 PM
jdmsiR20's Avatar
Default Re: d15b7-mini-me vs. d16z6 D-SERIES! (tonesdef)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tonesdef &raquo;</TD></TR><TR><TD CLASS="quote">stick with the d16z6 i went the mini me d15b7 route and the car wasn't that much faster and i threw a rod. With the d16 i'm running a 15.5 and its more reliable.</TD></TR></TABLE>
15.5? what kind of mods are you putting down? conditions? launch? daym, thats impressive!
Old Jun 26, 2003 | 08:15 PM
Risky Business
do you know why you threw a rod? i am interested to know because as i said, i will be doing this swap next week and i want to try and eliminate as many future problems as i can
Old Jun 27, 2003 | 12:37 AM
jdmsiR20's Avatar
up up and away
Old Jun 27, 2003 | 12:55 AM
krazyDOHC's Avatar
d15b7 z6 head ran perfectly fine for 3 years for daily driver, so i think its pretty reliable ....now its boosted at 5lbs 2 weeks so far so good
Old Jun 27, 2003 | 01:03 AM
jdmsiR20's Avatar
Default Re: d15b7-mini-me vs. d16z6 D-SERIES! (krazySOHC)
how does it feel? 1/4 times?
Old Jun 27, 2003 | 10:37 AM
jdmsiR20's Avatar
Old Jul 1, 2003 | 01:10 PM
jdmsiR20's Avatar
ttt
Old Jul 22, 2003 | 09:18 PM
JDMs1eeper's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BauleyCivic &raquo;</TD></TR><TR><TD CLASS="quote">
do you know why you threw a rod</TD></TR></TABLE>
high compression, no tuning, detonation... the list continues. Do it right and it will last. Do it shitty and it will be shitty. Its the same idea with the B20vtec and LSvtecs. Do it right the first time.
Old Jul 22, 2003 | 10:07 PM
jdmsiR20's Avatar
Default Re: d15b7-mini-me vs. d16z6 D-SERIES! (Typesi2nv)
my thread! back from the grave!
Old Jul 22, 2003 | 10:35 PM
Risky Business
yeah...and BTW i did my mini-me so you can read up on it by clicking the link in the sig. and you were right from the start, mini-me compression is 10.1:1 with a d16y8 head gasket
Old Jul 22, 2003 | 10:38 PM
Broken Gearbox's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmsiR20 &raquo;</TD></TR><TR><TD CLASS="quote">my thread! back from the grave!</TD></TR></TABLE>
so what did you do. ? or did you not make up your decision yet?
Old Jul 28, 2003 | 11:08 PM
jdmsiR20's Avatar
Default Re: d15b7-mini-me vs. d16z6 D-SERIES! (James.)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by James. &raquo;</TD></TR><TR><TD CLASS="quote">
so what did you do. ? or did you not make up your decision yet?</TD></TR></TABLE>
currently, i just found another job... i found a blown d16z6 block for cheap, and plan to start from the ground up... the d15b7 i have in the car now will be pulled once the d16z6 is built (with a y8 head)... the d15 will then turn into a mini-me...
so long story short... i'll have both motors to try out
anybody have an d-series parts for sale for cheap????
Old Jul 29, 2003 | 06:10 AM
Zer0DazE's Avatar
slap the y8 head on the b7 and use a z6 head on the d16. the z6 will flow better.
i just put a y8 head on my b7 over the weekend as a temp till i get time to finish my other motor. it gives a 10.5:1 cr and i swear with 2 deg cam retard the damn thing pulls to 8400 (8700 indicated on the tach). granted i have a lightend flywheel and **** and UR pulley, but it shouldnt make that much of a difference.
its amazing how bad the dx gearing is, i pulled 75 mph in 2nd gear and probably could have gotten a little more.
Old Jul 29, 2003 | 06:32 AM
mycivicdx's Avatar
if you do the mini-me make sure you swap the intake manifold as well. Get the p28 to run your vtec, it will pull better than the rpm activated switch. y8 head works best with the d15b7.
Old Aug 1, 2003 | 04:50 PM
jdmsiR20's Avatar
Default Re: (mycivicdx)
yea yea, thanks all for the replies... the new motor should be in my hands within a couple weeks... i'mma try and do a ghetto-ized write up, let you guys know how it went...
Old Aug 1, 2003 | 05:30 PM
JV's Avatar
JV
Who?
Default Re: (jdmsiR20)
I always see people making mini-me's out of the B7. Is it possible to do the Z6/Y8 head swap onto a D15B8 (CX motor)?
Isn't the block the same as the B7, but with an 8 valve head?
Old Aug 1, 2003 | 05:36 PM
JaeOne3345's Avatar
Default Re: (JV)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JV &raquo;</TD></TR><TR><TD CLASS="quote">I always see people making mini-me's out of the B7. Is it possible to do the Z6/Y8 head swap onto a D15B8 (CX motor)?
Isn't the block the same as the B7, but with an 8 valve head?</TD></TR></TABLE>
JV, sup dude. you can use the CX block, but make sure the pistons have reliefs for 16 valves and not just 8.
Old Aug 1, 2003 | 05:40 PM
JV's Avatar
JV
Who?
Default Re: (JaeOne3345)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JaeOne3345 &raquo;</TD></TR><TR><TD CLASS="quote">
JV, sup dude. you can use the CX block, but make sure the pistons have reliefs for 16 valves and not just 8.</TD></TR></TABLE>
Holy chit!
I never even thought about that. I was planning on swapping a B7 head onto the B8 block in my hatch just to get her running, and that never even crossed my mind.
Thanks man...
playingmilitary
Feb 21, 2013 04:02 PM
93eghb
Feb 17, 2008 11:44 AM
JdM_Eg_6
14
Feb 5, 2006 12:20 PM
Nerologic
18
Feb 11, 2004 07:46 AM
buskethead
May 20, 2003 04:02 PM
