Custom bent exhaust or rsr exhaust?
Old Jun 26, 2003 | 01:22 AM
CivicNA's Avatar
Default Custom bent exhaust or rsr exhaust?
ok so my buddy with itr is to lazy to post so ill post it for him and i also wanna be proven right. I said "go buy the rsr exhaust tomorrow". he says "no ill just get like a skunk 2 canister and have a custom 2 1/2 inch exhaust mendral bent". rsr will be about 600 shipped the custom should be about 400. what way should he go? will the hp with the 2 1/2 custom be better than the rsr? he has money for to buy ether one. jus lemmy know what you guys think thanks
Old Jun 26, 2003 | 02:40 PM
CivicNA's Avatar
Default Re: Custom bent exhaust or rsr exhaust? (CivicNA)
BUMP is 2 1/2 inch to big?
Old Jun 26, 2003 | 03:04 PM
vtec.dc2's Avatar
well.. if rsr isn't 2.5", i don't see a point of using muffler from that exhuast on larger piping..
if custom exhaust is mandrel bent and put together well, it shouldnt make a difference, but diameter will matter if you're going to push for more hp,
i also think stock exhaust is good enough for mild boltons..
Old Jun 26, 2003 | 07:56 PM
Padawan's Avatar
Darth ModerVader
A properly built custom 2.5" exhaust will almost definately out-perform the RS*R on an ITR.
Old Jun 26, 2003 | 08:47 PM
CivicNA's Avatar
Default Re: Custom bent exhaust or rsr exhaust? (Padawan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Padawan &raquo;</TD></TR><TR><TD CLASS="quote">A properly built custom 2.5" exhaust will almost definately out-perform the RS*R on an ITR. </TD></TR></TABLE>
the place he is going to bring it to is a mom and pop place. im not sure how well they could do it
Old Jun 26, 2003 | 09:16 PM
Padawan's Avatar
Darth ModerVader
If it will truly be mandrel-bent, the determining factors will be the components being used (i.e. resonator, muffler). As long as quality parts are chosen, there shouldn't be a problem. In this case, he'll want a 2.5" straight-through muffler and at least one quality resonator sized to suit his sound preference.
Old Jun 26, 2003 | 09:24 PM
TypeR 599's Avatar
what would you consider a quality resonator one can buy by itself? i'm looking for a good resonator to tone down this bumble bee under my car
Old Jun 26, 2003 | 09:26 PM
CivicNA's Avatar
oh he has no plans to put on a resonator. i was like dude ur sheeight is gunna be so loud. he dosnt care. i told him. get a magna flow res and stay away from the noise polution tickets. but we will see what he does.
thanks for the imput
Old Jun 27, 2003 | 04:42 AM
00MRSi's Avatar
Dood, you're giving your friend good advice. If he does not want to follow it, fockem. Let him get some POS exhaust that sounds like a weedwacker.
On a more serious note, if the place isn't a reputable exhaust shop, I'd buy the Skunk2/RSR Invidia N1 or look for Kteller on this board. He sells really nice, affordable 2.5" catbacks that just need to be welded together..
Old Jun 27, 2003 | 06:03 AM
fredtoast's Avatar
I think RSR makes a 2.5", but I would recommend the custom system. If the shop really does mandrel bends then it is no "mom and pop" place. The reason that I went custom was that I wanted a 2.5" system with two resonators like the stock set up but also with a straight through muffler.
Your buddy probably doesn't need a 2.5" if he just has bolt ons, but it won't hurt.
To me it boils down to the fact that it will save him $200.00.
Old Jun 27, 2003 | 06:17 AM
.RJ's Avatar
.RJ
Default Re: Custom bent exhaust or rsr exhaust? (fredtoast)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fredtoast &raquo;</TD></TR><TR><TD CLASS="quote">To me it boils down to the fact that it will save him $200.00. </TD></TR></TABLE>
So when he throws it away and buys a decent exhaust, he wasted $400. Just depends on how you wnat to look at it.
Old Jun 27, 2003 | 06:51 AM
fredtoast's Avatar
Default Re: Custom bent exhaust or rsr exhaust? (.RJ)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .RJ &raquo;</TD></TR><TR><TD CLASS="quote">So when he throws it away and buys a decent exhaust, he wasted $400. Just depends on how you wnat to look at it.</TD></TR></TABLE>
So custom, mandrel bent exhaust systems aren't decent? That's news to me. I agree that if he gets one with no resonator it would be loud as ****, but that is a question of taste not quality.
Old Jun 27, 2003 | 07:10 AM
.RJ's Avatar
.RJ
So custom, mandrel bent exhaust systems aren't decent? That's news to me. I agree that if he gets one with no resonator it would be loud as ****, but that is a question of taste not quality.</TD></TR></TABLE>
I'm not saying that. I was commenting on the fact that his friend was clearly not intrested in following good advice.
RJ
Old Jun 30, 2003 | 07:18 PM
CivicNA's Avatar
this is the most confusing post i have ever had. i think its great you guys are giving ur imput but its kinda hard to weed threw it. so basicly i figure his best bet is the rsr over the custom bent because it wont be like a performance shop doing it its just a normal muffler shop not one KNOWN for good hi-perf cat backs.
Old Jul 3, 2003 | 08:24 AM
fredtoast's Avatar
I'd like some more details on the shop. Mandrel bent piping is not that common. If this place does mandrel bending then I would think it would be a top of the line establishment. There is no rocket science invloved in making a cat back. It is not as complicated as designing a header. All they have to do is make it as straight as possible.
Old Jul 3, 2003 | 11:31 AM
00MRSi's Avatar
If a "reputable" exhaust shop is located in your area, that has "mandrel bent" piping available, then check it out. If not, just get a decent aftermarket catback like the Skunk2/RSR and call it a day.
AYB18c
Dec 25, 2017 12:22 PM
big-cat
Mar 20, 2007 08:05 AM
gsrguy150
Jul 8, 2005 10:04 AM
Hairy Gorilla
Sep 19, 2002 03:45 PM
jond
Aug 15, 2002 07:45 PM
