Headgasket problem/questions???
Old Jun 25, 2003 | 08:23 PM
IEATLINT's Avatar
Default Headgasket problem/questions???
im going to be taking my head off sometime this week because i believe i have a blown headgasket. now, my problem comes when selecting a new gasket. i have a b18b that has been bored to 2.0L, what type of gasket should i get?? should i get an OEM B20 gasket??? (i know it sounds stupid, im just guessing) or should i get a oem ls gasket and cut it out??? also should i get an aftermarket gasket or just stick to oem parts???? thanx
Old Jun 25, 2003 | 10:44 PM
IN VTEC's Avatar
Default Re: Headgasket problem/questions??? (IEATLINT)
If you've got a 84mm bore, you can use the B20B/Z head gasket.
Otherwise, look into getting a different size from Cometic.
Old Jun 26, 2003 | 12:02 AM
J2turbo21's Avatar
Default Re: Headgasket problem/questions??? (IN VTEC)
Yes used the b20 head gasket because it would be the easiest.You can also get a stock LS hg and bore it out to 84mm.
Old Jun 26, 2003 | 12:56 PM
IEATLINT's Avatar
thanx guys...which one should i go w/ though, any preferences???? should i just get an oem B20 or bore out an oem b18b or should i get an aftermarket gasket???
Rheg6
20
Sep 16, 2009 07:45 PM
SOHCD16y8
Oct 24, 2008 04:29 AM
freakin
Mar 5, 2005 09:03 PM
HX_Guy
Nov 13, 2001 06:36 AM
