EG Rear LCA...USDM and JDM are different??
Old Jun 25, 2003 | 07:48 PM
lowexr's Avatar
Default EG Rear LCA...USDM and JDM are different??
I bought a Cusco coil over suspension....I had a ITR LCA on it...but the guy told me that it came from an EG...
and on the cusco web site the serial number I have on my coilover is corresponding to the EG6 set-up
does JDM EG have different LCA than we have?
Old Jun 25, 2003 | 08:10 PM
_BEN_'s Avatar
Default Re: EG Rear LCA...USDM and JDM are different?? (lowexr)
The EG6 and DC2 LCA's are the same. So if you have them there should be no problems.
EDIT: If you look t alot of jdm shock manufactures and compare the serial numbers for the shocks will be the same for EG and DC chassis. Why? Because they are the same except for the springrates. Right now I have DC2 coilovers on my EG6. (Yes Its a EG6 not an EH)
Old Jun 25, 2003 | 08:32 PM
eg crunkmonster's Avatar
ITR LCAs
EG LCAs
Old Jun 25, 2003 | 08:36 PM
SkyeC's Avatar
Boba Connoisseur
25 Year Member
Japanese 92-95 Civic (EG6) = ITR style control arm
End of story.
Old Jun 25, 2003 | 08:42 PM
acydphryck's Avatar
Default Re: EG Rear LCA...USDM and JDM are different?? (eg cookiemonster)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eg cookiemonster &raquo;</TD></TR><TR><TD CLASS="quote">ITR LCAs
EG LCAs
i don't think he wants to spend $200 for lower control arms...you can get 'em brand new from the dealership for $100 a pair...
Old Jun 25, 2003 | 08:47 PM
lowexr's Avatar
Default Re: EG Rear LCA...USDM and JDM are different?? (SkyeC)
tanx for the good anwser...
that's what I tought....EG6 JDM have ITR style LCA...
other question now...
what Sway bar can I use on the ITR/JDM EG LCA??
GSR?..GS??..ITR(probably)
Old Jun 25, 2003 | 09:12 PM
euclid's Avatar
i am 80% sure you can use any factory rear sway bar with the itr contol arms as long as you are using the itr endlinks.
100% sure you can use the itr bar with the itr or japaneese eg rear lca.
Old Jun 25, 2003 | 10:14 PM
SkyeC's Avatar
Boba Connoisseur
25 Year Member
Default Re: EG Rear LCA...USDM and JDM are different?? (euclid)
I'm using LS endlinks and an LS rear swaybar on ITR LCAs. Works fine.
Old Jun 25, 2003 | 11:58 PM
R you serious's Avatar
Default Re: EG Rear LCA...USDM and JDM are different?? (nosepkr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nosepkr &raquo;</TD></TR><TR><TD CLASS="quote">The EG6 and DC2 LCA's are the same. So if you have them there should be no problems.
EDIT: If you look t alot of jdm shock manufactures and compare the serial numbers for the shocks will be the same for EG and DC chassis. Why? Because they are the same except for the springrates. Right now I have DC2 coilovers on my EG6. (Yes Its a EG6 not an EH) </TD></TR></TABLE>
WRONG!!! not all dc2 are the same there eistein. itr is COMPLETELY different from other model integras
Old Jun 26, 2003 | 02:16 AM
_BEN_'s Avatar
Default Re: EG Rear LCA...USDM and JDM are different?? (R you serious)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by R you serious &raquo;</TD></TR><TR><TD CLASS="quote">
WRONG!!! not all dc2 are the same there eistein. itr is COMPLETELY different from other model integras</TD></TR></TABLE>
Photo courtesy of Technica Sport
If they are not exactly the same, are damn close.
Old Jun 26, 2003 | 04:59 AM
VWkila's Avatar
ITR LCA uses "truck-like" shocks in the rear.
So the shocks for other Integras and Civics will not fit in the rear. But front fits fine. I have them on my Civic.
Old Jun 26, 2003 | 06:37 AM
Brewer's Avatar
Default Re: EG Rear LCA...USDM and JDM are different?? (VWkila)
The guy said that the shocks came with LCA's on them, so all he has to do is bolt on those ITR LCA's and he'll be good to go
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">Japanese 92-95 Civic (EG6) = ITR style control arm
End of story.</TD></TR></TABLE>
Old Jun 26, 2003 | 06:50 AM
Apex i ITR's Avatar
From: Toronto, Canada currently residing in ATL, GA, USA
Default Re: EG Rear LCA...USDM and JDM are different?? (BrewerHatch)
ITR LCA's=EG6 (Japanese Civic) LCA's.
VTi_b0i
27
Oct 21, 2012 03:45 PM
bmoua
May 10, 2007 12:04 PM
puregroove
Dec 20, 2005 02:43 PM
UnhuZ
20
May 30, 2005 04:56 AM
