Best Cams for a ...
B16B engine ?
Crower ?
Crane?
Toda?
Jun ?
Are they better that stock CTR cams ?
I don't want to have to cut the pistons for valve clearence if I can avoid it ...
I just got the engine in the car and running .. I don't want to pull it all apart again ..
Crower ?
Crane?
Toda?
Jun ?
I fI go with Toda B's - will I have a piston to valve clearance problem?
Is the stock CTR valve train not strong enough for these cams ?
When you mentioned valve train, I assume you mean springs and retainers ... what springs do you recomend ....
Thanks for your help
From the Toda website "Using Spec C camshafts on engines with milled cylinder heads, thin head gaskets, or non TODA Racing high compression pistons may cause valve-to-piston clearance issues."
My head has been decked and I am using a thin head gasket ... I guess that rules out the Toda C's for me ...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lcopas »</TD></TR><TR><TD CLASS="quote">From the Toda website "Using Spec C camshafts on engines with milled cylinder heads, thin head gaskets, or non TODA Racing high compression pistons may cause valve-to-piston clearance issues."</TD></TR></TABLE>
Thats why you clay the motor.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by J2turbo21 »</TD></TR><TR><TD CLASS="quote">
Thats why you clay the motor.</TD></TR></TABLE>
Exactly, that's how you'll find out if C's work or not.
nsx-Animal
Sep 20, 2001 12:50 PM
