HELP! Code 8 and 14! B18A in CRX DX
Old Jun 25, 2003 | 06:29 PM
RotiEatter's Avatar
Ditto
Default HELP! Code 8 and 14! B18A in CRX DX
Ok I have had this problem where during partail throttle my car is fine. But during full throttle it bogs out and sort of stutters there. I am throwing Codes 8 and 14.I don't think my IACV could cause this since it idles fine. Do you think code 8 the top dead center sensor could cause this? If so , i will buy a new distributor. I have gone over the wiring and it looks fine. i even tried switching the 2 new wires that run to the distributor and it didn't do anything. What should I do? TIA.
Old Jun 26, 2003 | 02:25 PM
RotiEatter's Avatar
Ditto
Default Re: HELP! Code 8 and 14! B18A in CRX DX (RotiEatter)
I found out that the guy gave me a PM6 which is a sohc non-vtec ECU. You think this could be causing my porblem? If so , I am going to try a ZC ECU that a friend of mine has.
Old Jun 26, 2003 | 04:34 PM
Racer613's Avatar
I think you should smack the guy who gave you the ecu, and threaten him with bodily harm till he gives you the right one...
Old Jun 26, 2003 | 07:13 PM
RotiEatter's Avatar
Ditto
Default Re: HELP! Code 8 and 14! B18A in CRX DX (Racer613)
Well I tried the ECU and it didn't work. I am running out of options here and I really need your guys help.
civicb1812345
17
Aug 21, 2013 09:37 PM
661rex89si
Apr 12, 2011 01:04 AM
Doodson
Aug 1, 2006 09:59 PM
civhatch90
10
Mar 2, 2006 05:00 AM
