zc swap question
Old Jun 25, 2003 | 05:12 PM
SiRWannabe's Avatar
Default zc swap question
I'm doing my zc swap into a 91 dx and my problem is that the injectors arn't firing. I'm using a Si ecu(pm6) with a 89 integra dizzy, could that make the injectors not fire??? I've checked my grounds and my wiring over and over again so its not that because at the very least 2 injectors should fire
Old Jun 26, 2003 | 06:56 AM
jlicrx's Avatar
Default Re: zc swap question (SiRWannabe)
ECU and distributor should be o.k. - try switching the 2 white wires at the distributor plug
Old Jun 26, 2003 | 08:13 AM
DJ_SaNdOz's Avatar
Default Re: zc swap question (jlicrx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jlicrx &raquo;</TD></TR><TR><TD CLASS="quote">ECU and distributor should be o.k. - try switching the 2 white wires at the distributor plug</TD></TR></TABLE>
Yea- make sure that your dizzy is wired color to color - and try testing the voltage going to teh injectors.
Old Jun 26, 2003 | 04:52 PM
SiRWannabe's Avatar
Default Re: zc swap question (DJ_SaNdOz)
tested the voltage to the injectors, its about 10v I belive, but I'll check to make sure the dizzy is wired color to color
Old Jun 26, 2003 | 07:34 PM
DJ_SaNdOz's Avatar
who did your wiring? did you get a harness or did you DIY? I'm assuiming that you meant teh MPFI wiring right? if so, has anyone else checked it out? does the car do anything when you try to turn it over?
Old Jun 27, 2003 | 09:13 PM
SiRWannabe's Avatar
I used modified my exsisting harness,a dx. the guy who did it used to be a honda mechanic so I'm confident of his work. No one else has looked at the wiring....as for trying to start it...from what I know is that it trys to start but when you take the spark plugs out, there is no fuel smell.
Old Jun 28, 2003 | 05:33 AM
DJ_SaNdOz's Avatar
do you hear the fuel pump priming at all? it should make a faint clicking sound when you go to turn on the ignition, if it's not that then I am not sure where to direct you.g/l
Old Jun 29, 2003 | 04:52 PM
SiRWannabe's Avatar
fuel pump works..it primes right to the injectors...still have to try to wire the dizzy color to color...will try that next
Old Jun 29, 2003 | 05:08 PM
blah13's Avatar
The only trouble you might run into with the dizzy wiring are the 2 white ones, ones supposed to have a red stripe so its hard to tell. If you wire it up and still no go, switch the 2 whites.
Old Jun 29, 2003 | 07:40 PM
hb mania 91's Avatar
could you have the wrong injectors? I know the 88-91 are peak hold inj. and the 92-95 are saturated inj. Not sure....you guys can back me up here but will they interchange? I know you can run 88-91 on a 92-95 setup but can you do the opposite?
Old Jun 29, 2003 | 08:34 PM
SiRWannabe's Avatar
Default Re: (hb mania 91)
Here is my plan of attack
I'm getting a friend to lend me his CRX si to test out the 3 pm6 ecu's I have, if they check out, then I'll check my dizzy wiring, if that doesn't work then I bougt an entire Si wiring harness and were gonna swap that in. I know its easier to mod my exsisting DX harness but we can rob plugs off of that harness to make the Si one work, and if it still isn't running(which I hope not) anyone wanna buy a car?
Old Jun 30, 2003 | 03:19 AM
slywfbpsi's Avatar
Default Re: (SiRWannabe)
it's alot easier just to check two wires on the dizzy then, trying to go thru 3 ecus
Old Jun 30, 2003 | 08:35 AM
DJ_SaNdOz's Avatar
Default Re: (slywfbpsi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slywfbpsi &raquo;</TD></TR><TR><TD CLASS="quote">it's alot easier just to check two wires on the dizzy then, trying to go thru 3 ecus</TD></TR></TABLE>
he's right dude- the wires are easy to change- I would start there. now, since you are doing the mpfi swap did you make sure that the resistor box is hooked up to the injectors correctly, etc? I'm just trying to throw idea's out there for you. do you have the civic/ZC manual?
Old Jun 30, 2003 | 09:33 AM
I8ayellowcrayon's Avatar
If the car was already MPFI, will the ZC be a direct swap? I'm using a PM6 and modified DX harness.
Old Jun 30, 2003 | 10:49 AM
slywfbpsi's Avatar
Default Re: (I8ayellowcrayon)
yes all d series engine are a direct swap except the d16a1s.
Old Jun 30, 2003 | 06:25 PM
SiRWannabe's Avatar
I am gonna go over all of the wiring one more time before I resort to using the Si harness...I'm gonna use fourthgenhatch's write up since its the most detailed I've seen to date, gonna check the dizzy wires as well, I'll be doing that on wednesday. I'll let you know how it goes
Old Jun 30, 2003 | 07:22 PM
Yeah, I know they all mount the same, but will my PM6 work with a ZC?
Old Jul 1, 2003 | 12:07 AM
SiRWannabe's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by I8ayellowcrayon &raquo;</TD></TR><TR><TD CLASS="quote">Yeah, I know they all mount the same, but will my PM6 work with a ZC?
the pm6 will work but a pg7 will work better (88-89 integra) you can find some around. If you're lucky enough to get a pm7(zc ecu) that would be the best one but they're rare
Squeek485
Jan 26, 2017 10:54 AM
89civichb
Jul 24, 2008 01:35 PM
svacca1
Aug 5, 2007 04:17 PM
Stebo77
10
Dec 23, 2002 08:54 AM
