Check engine light = missfire in cylinders, what else do i need to check
Old Jun 25, 2003 | 04:16 PM
willyboyK20's Avatar
Default Check engine light = missfire in cylinders, what else do i need to check
Check engine light came on today out of nowhere.
I went to local honda mechanics to pull the code and it read misfire in cylinders. I changed the rotor, cap, coil, spark plugs
Only thing left is the igniter, and wires.
Could get the igniter, mucho dinero and payday is friday
anything else i could check.
Car runs okay but when you floor it, it stumbles and noticably misses.
I used to do it off and on, only around 2500-3000 but now its every where.
Old Jun 25, 2003 | 05:09 PM
godnf8's Avatar
Default Re: Check engine light = missfire in cylinders, what else do i need to check (willyboyD16)
blown headgasket or bent valves can also cause that code (knows from experience) 71, 72, 73, 74 codes. run a compression and leak down test. If you don't know how do a search. gl
Old Jun 25, 2003 | 06:09 PM
Draco's Avatar
I had that same problem with my car. Stock 94' Si. Replaced the wires and it went away. I hope you have the same problem.
Old Jun 25, 2003 | 06:10 PM
GetawayInMoscow's Avatar
Default Re: Check engine light = missfire in cylinders, what else do i need to check (Draco)
Maybe your sparkplug wires aren't on the right way...
Old Jul 2, 2003 | 01:35 PM
Default Re: Check engine light = missfire in cylinders, what else do i need to check (GetawayinMoscow)
everything is fixed.
It was the igniter. but i went ahead and changed everything but the distribut housing.
Old Jul 2, 2003 | 04:23 PM
btw how do I clear the code so the engine light will come off?
Old Jul 2, 2003 | 05:19 PM
NrG's Avatar
NrG
remove the positive cable from your battery, go into the car and hold down the brakes for 10seconds, then plug it all back in
Old Jul 2, 2003 | 08:10 PM
Default Re: Check engine light = missfire in cylinders, what else do i need to check (NrG)
thanks
91accordflow
Jun 6, 2009 05:12 PM
Ed 341
Mar 8, 2006 02:45 PM
jvcnyc
Jun 2, 2004 06:23 PM
B_1_8_hatch
Aug 12, 2002 07:41 PM
