Starting out with autocrossing question?
what are the minimal things you have to have to be able to get onto the track? i know such things like a helmit and im pretty sure you have to have like a 5 point harness. those things are just like common sence things.. but what else do you have to have done to your car to be able to race??? ive done a search so no one flame me on that one.. but will someone please help fill me in? thanks..
No 5-point harness, just a normal seatbelt. Some regions supply rental helmets, so you don't even need to buy one.
What you need : lug nuts on your wheels, a battery that isn't going to fall out of your car, air in your tires, gas in your tank.
A valid driver's lisence helps too...
Your throttle return spring needs to be working correctly as well.
Clean everything out of the car that isn't bolted down (ie floor mats, CD case, misc bits o'paper)
When you say "to be able to get onto the track?" what do you mean? You said Autocross, but when we say "track," we usually mean a road course. Which do you mean? Autocross (parking lot with cones) or a lapping day at a track?
And neither require a 5-pt harness. In fact, most will tell you that a harness is a bad thing on a track without a roll-bar. At an autocross, that is debateable.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Aron Parsons »</TD></TR><TR><TD CLASS="quote">Just make sure your vehicle is in good running order. Nothing special is required.</TD></TR></TABLE>
what he said.
When you go to an autocross the first thing you'll notice is a ton of non-race looking cars. In fact, a lot of people autocross cars you wouldn't even consider a sports car. Just about anything can compete. So just get a helmet (or borrow one), make sure you have decent tire pressure, and have a blast. Then you can worry about mods later
what he said.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote »</TD></TR><TR><TD CLASS="quote">In fact, a lot of people autocross cars you wouldn't even consider a sports car. </TD></TR></TABLE>
I know you said you did research, but I figured I'd add to that "load of books you're carrying".
http://www.autox4u.com/novice.htm
http://www.nerdsracing.com/Xlist.htm
Hope this helps... Most important thing is have FUN.
Look at the top of the forum, RJ has a sticky post that has a bunch of great sites to get into on getting started. In fact, here it is.
https://honda-tech.com/zerothread?id=353425
Holy christ I run if I was working the fast sweeper and saw that thing motoring at me.
Nice hat on the corner worker also......he get a free bowl of soup with it?
http://www.pbase.com/image/17705479/medium
This is one of my favorites... sorry I don't know how to get the photo to appear here.
SicNA94TegGsR
19
Jan 18, 2004 08:29 PM
AcuraRacer112
Feb 25, 2003 05:24 AM
Brett@SoloRacer.com
May 21, 2002 06:57 PM
