LS/VTEC build....please help
Old Jun 25, 2003 | 03:12 PM
AttikTuning's Avatar
Default LS/VTEC build....please help
I am putting together an LS/VTEC next week in a 1996 Acura Integra LS. I have seen many posts and lists of the parts i need to do an LS/VTEC swap into civics etc... but what i need is an EXACT list of what extra parts i will need to bolt the GSR head to the LS block in an LS integra.
Please help me out if you can
Old Jun 25, 2003 | 04:30 PM
eg_type_r93's Avatar
gsr head, intake manifold, throttle body & cable, gsr distributor,
then u need either a vtec oil & water pump to go with a vtec timing belt or use what u got and use all non vtec parts which u have, all have to be the same tho
vtec ecu, ls head gasket, gsr head bolts,
wiring harness use stock and wire up vtec and knock
think thats about it >>>>>>>
add on what i forgot out?
Old Jun 25, 2003 | 06:42 PM
intekragsr's Avatar
Default Re: (eg_type_r93)
Oil line, fittings, special machined dowels.
adamintegra06
Nov 19, 2008 05:32 PM
ThoRoughEG6
Apr 13, 2007 10:07 PM
JDMJunior
Dec 17, 2005 11:05 AM
1man
Jul 28, 2003 10:01 AM
JDM_Risa
Mar 16, 2003 01:42 PM
