tips on removing the bitch pin?>?( 88 REX)
Old Jun 25, 2003 | 02:16 PM
gocivicgo's Avatar
Default tips on removing the bitch pin?>?( 88 REX)
OK the bitch pin inb the tranny shift linkage.....any tips on getting the stupid
fu__!_g thing out??? PLEase help, i ahve the tranny sold and im haveing probs getting it out....
Old Jun 25, 2003 | 02:20 PM
Hcivic88's Avatar
Default Re: tips on removing the bitch pin?>?( 88 REX) (gocivicgo)
get a punch the same size as the pin, and a hammer. line the punch up in the hole, and swing the hammer at it. took me about 3 hits to get it out, and that was the first time the pin was ever taken out too.
Old Jun 25, 2003 | 02:38 PM
SIRX's Avatar
Default Re: tips on removing the bitch pin?>?( 88 REX) (Hcivic88)
or use a 3/8" bolt and grind the threads off of it, or use an AC bracket bolt. or the right sized punch as mentioned before. All three work great.
Old Jun 25, 2003 | 02:57 PM
4drEF's Avatar
Keyboard Humorist
I believe the right size punch is an 8mm.
Old Jun 25, 2003 | 03:51 PM
VTgringo's Avatar
Default Re: tips on removing the bitch pin?>?( 88 REX) (4drEF)
if you try to use anything but the exact size of the pin to hit it out with the pin will just tighten up more when you strike it. make sure your not using anything with a taper.........man that thing was a bitch when i didn't know what i was doing
Old Jun 25, 2003 | 07:20 PM
CRXRageD's Avatar
9mm punch and lots of patience.
Old Jun 25, 2003 | 10:39 PM
HandCommand's Avatar
Default Re: tips on removing the bitch pin?>?( 88 REX) (CRXRageD)
I personally use a 5/16 flat faced punch, not tapered to get that pin out. DO NOT use a tapered punch. It will just spread the pin out more and make it more difficult to get loose.
I guess SNAP-ON makes a special punch that the correct size and even has a "guide pin" thingy to center the punch on the roll pin.
I need to pick up one of those. In the meantime, my punch has worked fine for me.
Old Jun 25, 2003 | 10:41 PM
SIRX's Avatar
Default Re: tips on removing the bitch pin?>?( 88 REX) (HandCommand)
yeah the snap-on one is badass. but really it's not as hard to get out as everybody makes it seem
Old Jun 25, 2003 | 10:45 PM
Vinceg99's Avatar
Default Re: tips on removing the bitch pin?>?( 88 REX) (SIRX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SIRX &raquo;</TD></TR><TR><TD CLASS="quote">yeah the snap-on one is badass. but really it's not as hard to get out as everybody makes it seem</TD></TR></TABLE>You can find those a lot of places granted its not a snap on but still you can find it with the guide pin at like Sears or where ever craftsmen is sold I think that I might have even seen them at Walmart??!!
Old Jun 25, 2003 | 10:53 PM
SIRX's Avatar
Default Re: tips on removing the bitch pin?>?( 88 REX) (Vinceg99)
Vince weren't you the one that wanted to use a bolt for the bitch pin? what ever came of that?
Old Jun 25, 2003 | 11:06 PM
Vinceg99's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SIRX &raquo;</TD></TR><TR><TD CLASS="quote">Vince weren't you the one that wanted to use a bolt for the bitch pin? what ever came of that?</TD></TR></TABLE>
I never said that I wanted to use one I was just trying to find out info about it and see if it was possible. here is the post btw... https://honda-tech.com/zerothread?id=540890 I just heard people talking about it so before I did something I wanted to see what was up about it...
Old Jun 26, 2003 | 04:47 AM
USDM 4G VTEC's Avatar
i use one of my big phillips screwdrivers from craftman.... go under hood and put the tip on the pin.... lean the screwdriver against the rear motor mount....... use a long tube(one from jack or cherry pciker works) place it on top of the screwdriver and hammer that thing down... usually comes out in one hit...
Old Jun 26, 2003 | 04:59 AM
Jared's Avatar
Default Re: tips on removing the bitch pin?>?( 88 REX) (USDM 4G VTEC)
I don't understand why you guys make such a big deal of that pin. It's just a roll pin. Buy a roll pin punch, it isn't tapered and has a centering ball to help you drive it out. Any tool manufacturer makes a set. I think the one I use is a snap on 1/4".
Old Jun 26, 2003 | 05:36 AM
Davep's Avatar
Default Re: tips on removing the bitch pin?>?( 88 REX) (Jared)
Yeah, what the problem here....
punch, hammer, pound, pin falls out.
thundernutz
Sep 27, 2009 04:22 AM
aimbot
Apr 29, 2009 02:08 PM
redsidriver
18
Mar 24, 2009 12:19 PM
leroyb
Apr 4, 2007 11:26 AM
slowpokesi
May 11, 2005 11:36 PM
