what kind of spring can you use on a stock ITR
Old Jun 25, 2003 | 01:00 PM
BassBoy19's Avatar
Default what kind of spring can you use on a stock ITR
I asked myself this question : what kind of drop springs can you use that can work well with the stock dampers without bouncing.... because I find the stock ITR a little bit too high maybe a 3/4 inch lower will be nice.... thanks... I know comtech sells 3/4 inches springs for ITR but I was not able to get the info from comptech to see of they work well with stock shocks....
Old Jun 25, 2003 | 01:35 PM
Ferrell's Avatar
Default Re: what kind of spring can you use on a stock ITR (BassBoy19)
spoon springs are made to go with the stock shocks?
Old Jun 25, 2003 | 02:45 PM
Denny's Avatar
Default Re: what kind of spring can you use on a stock ITR (Ferrell)
get tein s-tech springs.it is a perfect ride. s-tech are chit with other honda cars, but work really well with type r struts.
hope this pic helps u out. it isnt slammed but lowers it just enough.
Old Jun 25, 2003 | 05:59 PM
itr-j's Avatar
Default Re: what kind of spring can you use on a stock ITR (TypeR882)
looks good
Old Jun 25, 2003 | 07:35 PM
BassBoy19's Avatar
thanks man the ride just look nice and clean.. are you sure the ride isn'T bouncy at all with stock dampers, do tein produce special application for ITR ?
Old Jun 25, 2003 | 07:57 PM
FOrSfEd's Avatar
Default Re: (BassBoy19)
yeah I was thinking about Tein as well. I would also like to know how it rides and handles over stock.
Lee
Old Jun 25, 2003 | 08:09 PM
98itR484's Avatar
Default Re: (FOrSfEd)
kg/mm
Old Jun 25, 2003 | 08:10 PM
Fujiwuji's Avatar
would the tein springs be too low for JDM dc sports headers?
and about how long would stock struts last with these springs ?
Old Jun 25, 2003 | 08:20 PM
.RJ's Avatar
.RJ
Default Re: (Fujiwuji)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Fujiwuji &raquo;</TD></TR><TR><TD CLASS="quote">about how long would stock struts last with these springs ?</TD></TR></TABLE>
Any time you lower the car on stock shocks or increase the spring rate (which is usually neccesary to avoid hitting the bumpstops) you comprimise the life of the shock.
bikerballrEM2
Mar 31, 2008 08:52 PM
ITR010342
Sep 6, 2007 06:03 AM
uncleben
Jun 21, 2004 05:24 AM
lowlight
Jun 24, 2003 12:45 PM
Edwin
May 8, 2002 07:23 PM
