Lightened fly wheel or new clutch?
Old Jun 25, 2003 | 10:45 AM
SpyderZEX's Avatar
Default Lightened fly wheel or new clutch?
I recently purchased a JDM B18C (GSR) engine swap for my 95 civic dx. Anyway, I am running really low on cash and I don't have the money to purchase both a clutch and a new fly wheel. I figured the clutch would be a good thing to replace for now since they tend to get a lot of wear. Ordinarily, I'd wait and save up the extra cash, but I want to get the engine in so that I can make sure everything else works properly.
Any help would be greatly appreciated. Thanks in advance!
Old Jun 25, 2003 | 10:49 AM
EE9's Avatar
EE9
Default Re: Lightened fly wheel or new clutch? (SpyderZEX)
Wait and do both... or you will regret it later...
Old Jun 25, 2003 | 10:52 AM
Katman's Avatar
Default Re: Lightened fly wheel or new clutch? (EE9)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EE9 &raquo;</TD></TR><TR><TD CLASS="quote">Wait and do both... or you will regret it later...</TD></TR></TABLE>
ditto.
Old Jun 25, 2003 | 10:54 AM
SpyderZEX's Avatar
I REALLY CAN NOT wait on this! My options are change one or the other now, or install the engine the way it is and then replace them both in a few months.
Old Jun 25, 2003 | 10:56 AM
Katman's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SpyderZEX &raquo;</TD></TR><TR><TD CLASS="quote">I REALLY CAN NOT wait on this! Anyother ideas?</TD></TR></TABLE>
well here's an option you can do...
Just buy a new 94+ GSR clutch DISC, but reuse the GSR pressure plate & throw-out bearing, and pick up an aftermarket lightend flywheel or...have the GSR f.wheel shaved down to 12-13lbs (which is prolly cheaper than buying an aftermarket unit).
Old Jun 25, 2003 | 10:58 AM
SpyderZEX's Avatar
Default Re: Lightened fly wheel or new clutch? (Katman)
Is it ok to reuse the pressure plate and throw out bearing?
Old Jun 25, 2003 | 11:09 AM
Katman's Avatar
sure it is...its kinda ghetto..but hey, what can you do?
just inspect it make sure nothing looks broken on the pressure plate. You might wanna buy a new throwout bearing though, they're about $20.
Old Jun 25, 2003 | 11:11 AM
K20  EG's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SpyderZEX &raquo;</TD></TR><TR><TD CLASS="quote">I REALLY CAN NOT wait on this! My options are change one or the other now, or install the engine the way it is and then replace them both in a few months.</TD></TR></TABLE>
Why not just wait.....is the money burning a hole in your pocket
Old Jun 25, 2003 | 11:17 AM
SpyderZEX's Avatar
Default Re: Lightened fly wheel or new clutch? (B20---Vtec)
NO the money is not burning a hole in my pocket. As I already said. I don't want to have the engine lying around my house for too long. However, the main reason is because I want to install the engine to make sure everything works. If I waited another month or two and had something go wrong that was the suppliers fault then he would not honor any kind of warranty. I want to get it in A.S.A.P. so that if anything is wrong, I can work it out now!
Katman, thank you for the advice, I really appreciate it. I think that is my only option right now.
Old Jun 25, 2003 | 11:21 AM
Katman's Avatar
Katman, thank you for the advice, I really appreciate it. I think that is my only option right now.</TD></TR></TABLE>
...word, good luck.
Old Jun 25, 2003 | 02:22 PM
raene's Avatar
Isn't it possible to resurface the pressure plate contact area? Seems to me that would be better than just throwing a new disc in it I don't mean reuse the same disc, but get the flywheel shaved + resurfaced, resurface the PP, and throw on a new disc + throwout bearing (yes, they're about $20).
Also check the wear on the fingers of the pressure plate... where the throwout bearing contacts them. If they're getting pretty thin you might just have to get a new clutch.
Old Jun 25, 2003 | 04:09 PM
Katman's Avatar
Default Re: Lightened fly wheel or new clutch? (raene)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by raene &raquo;</TD></TR><TR><TD CLASS="quote">Isn't it possible to resurface the pressure plate contact area? Seems to me that would be better than just throwing a new disc in it I don't mean reuse the same disc, but get the flywheel shaved + resurfaced, resurface the PP, and throw on a new disc + throwout bearing (yes, they're about $20).
Also check the wear on the fingers of the pressure plate... where the throwout bearing contacts them. If they're getting pretty thin you might just have to get a new clutch. </TD></TR></TABLE>
yep, all of what you said is possible....depends on what the guy wants to do and how much $$ he has..
eG6 driver3
Feb 1, 2008 08:26 PM
LS94tegra
Sep 7, 2007 08:08 PM
EFHbSi
Sep 16, 2005 07:11 AM
RasmusRic
Jul 3, 2004 03:43 AM
ramz7887
Feb 11, 2004 04:46 PM
