b16 block + gsr head = ?
Old Jun 25, 2003 | 10:11 AM
granada_sun's Avatar
Default b16 block + gsr head = ?
Will a gsr head fit on a b16 block with CTR pistons and cams without valves hitting? Stupid question, but no result in the search......and just want to make sure....
Old Jun 25, 2003 | 10:14 AM
CimorelliCRX's Avatar
Default Re: b16 block + gsr head = ? (granada_sun)
I would think so, if the B16 head fit then the GSR should fit.
Old Jun 25, 2003 | 11:58 AM
thats what i was thinking, but i didnt know if gsr valves were maybe longer than b16's especially where ctr pistons are domed, even though they've got valve slots in them......
Old Jun 25, 2003 | 01:12 PM
RexB16's Avatar
Default Re: (granada_sun)
it will fit just fine.
Old Jun 25, 2003 | 01:26 PM
VTgringo's Avatar
Default Re: (RexB16)
if the engine is out of the car i would do some what if scenarios just to be 100%
Old Jun 25, 2003 | 05:31 PM
SiR Kid's Avatar
New User
Default Re: (VTgringo)
It'll work fine and your compression will wend up at about 11.5-11.8:1.
b18c1 GSR's P72 head has a squared combusion chamber, where the b16a is circular and slightly larger volume, so with the b18c1 head, the compression is slightly higher than a b16a/ITR PR3 head.
Old Jun 25, 2003 | 05:51 PM
xtrafastcivic's Avatar
Default Re: (SiR Kid)
you take a simple question and you make a paragraph :\
Old Jun 25, 2003 | 10:00 PM
nah thats what i wanted to know i mean i knew the gsr head had higher compression than the b16, and since my plan is NA thats golden....
I guess my next question is how thin of a head gasket can I go with the same set up?? I mean will 2 layer mugen work alright?
Thanks for the input fellas, its appreciated.
Modified by granada_sun at 2:37 AM 6/26/2003
408EJ1
16
Jan 8, 2014 03:23 PM
blub18
Oct 4, 2006 07:51 AM
BI8B
Sep 11, 2003 08:38 AM
CBR
Aug 19, 2002 07:18 AM
Tyson Ballou
Dec 26, 2001 06:17 PM
