Another camshaft war!!!RS camshafts VS. All Manufactured stage 3 camshafts
Old Jun 25, 2003 | 09:39 AM
NorCalAllMtr408's Avatar
Default Another camshaft war!!!RS camshafts VS. All Manufactured stage 3 camshafts
i think or if someone did.....what about a comparison to the rs cams againest every other stage 3 camshaft on the market.....let the war begin!!!!
Old Jun 25, 2003 | 09:43 AM
gsrvx's Avatar
New User
Default Re: Another camshaft war!!!RS camshafts VS. All Manufactured stage 3 camshafts (NorCalAllMtr408)
What are the specs on the RS cams?
Old Jun 25, 2003 | 07:45 PM
Default Re: Another camshaft war!!!RS camshafts VS. All Manufactured stage 3 camshafts (RK)
the duration is bigger than a jun 3 cam but i will have the specs on it asap!!
Old Jun 25, 2003 | 08:41 PM
Mr Hammond's Avatar
a/k/a Jomo
Well that isn't saying much considering the JUN III is basically your average Skunk2 Stage 2 cam. Can't wait to see specs.
Old Jun 25, 2003 | 08:52 PM
cleanEG's Avatar
Default Re: Another camshaft war!!!RS camshafts VS. All Manufactured stage 3 camshafts (Mr Milano)
Well....I will post some dyno sheets when my motor is tuned...I finally have it running in good condition to break it in...so after next weekend I will tell all!
Old Jun 25, 2003 | 09:22 PM
MaxBoost's Avatar
New User
Default Re: Another camshaft war!!!RS camshafts VS. All Manufactured stage 3 camshafts (cleanEG)
I want to see RS cams vs Toda C vs Jun III vs Jun IV vs Toda D vs EF1 M24/E..lol
Old Jun 26, 2003 | 09:47 AM
here are the specs on the rs cams....
intake lift:12mm
exhaust lift:11.5
intake duration:294
exhaust duration:296
Old Jul 4, 2003 | 07:19 PM
cleanEG's Avatar
Default Re: (NorCalAllMtr408)
Well...I went to the dyno today and here were the results of my setup...
B18C bottom end w/ ITR pistons
RS Camshafts, dual valve springs, titanium retainers
RC 440 Injectors
Hondata s200
2.5 mandrel magnaflow exhaust
DC 4-1 2" collector ( biggest bottleneck in my system)
AEM CAI
62mm TB
Dont have a scanner right now so I will post the graph later...but here is what it put down on a DynaPak dyno @ Church Automotive Testing ( props to Shawn for great tuning job on this motor!)
207.5 whp
132ft/lb torque
For those concerned about comparing to a dynojet...whp is about 10hp difference depending on wheels used, tire pressure, etc...
Old Jul 4, 2003 | 07:20 PM
cleanEG's Avatar
Default Re: (cleanEG)
Also have a Skunk2 IM .....
Old Jul 4, 2003 | 07:29 PM
cleanEG's Avatar
Here is the before dyno on a dynojet....the after dyno was done on a dynapak so to compare the too it would put down about 197.5 whp on a dynojet....
Old Jul 4, 2003 | 09:54 PM
earl's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NorCalAllMtr408 &raquo;</TD></TR><TR><TD CLASS="quote">here are the specs on the rs cams....
intake lift:12mm
exhaust lift:11.5
intake duration:294
exhaust duration:296</TD></TR></TABLE>These specs match the Web Cam we have been using for 2 years.
Old Jul 4, 2003 | 10:07 PM
GokuSSJ4's Avatar
intake lift:12mm
exhaust lift:11.5
intake duration:294
this are the spec for Toda Spec D
Specifications:
Valve Lift Duration
Intake Primary 11mm 250
Intake Secondary 11mm 250
Intake High (VTEC) 12.9mm 305
Exhaust Primary 11mm 250
Exhaust Secondary 11mm 250
Exhaust High (VTEC) 11.9mm 315
it would be nice to compare but the D's will need a lot more CR to get the best out of them compare on your set up ...
Old Jul 4, 2003 | 10:27 PM
Beave0101's Avatar
RS Machine sent a cam out to Autowave about two monthes ago.
They Dyno'd the skunk2 stage III, which were running in a customers car, against RS's cam. The RS Cam curve was identical until 7800 and put around 6whp more than the stage III
edit: don't know the specs of the motor used but the numbers were above 200
Old Jul 5, 2003 | 01:50 AM
B18c5Kevin's Avatar
Great reply omniman, creative.
Old Jul 5, 2003 | 03:12 AM
J2turbo21's Avatar
Default Re: Another camshaft war!!!RS camshafts VS. All Manufactured stage 3 camshafts (Beave0101)
Which RS cams where they?They have a vtec eliminator and a reg type cam.
Old Jul 5, 2003 | 09:49 AM
earl's Avatar
Default Re: (omniman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by omniman &raquo;</TD></TR><TR><TD CLASS="quote">there is a lot more to a cam than the 3 specs given.......
open 1mm to close 1mm duration and peak lift make a triangle if you will (3 points of reference), however what the cam shape looks like between the 3 points will determine how good it is. you could have several cams that have the same exact 1mm open to 1mm closed duration and peak lift but have entirely different profiles. if you check duration from 7mm to 7mm on 2 different cams with the same specs you will probably see differences. lift and duration #'s are decieving the dont really tell you much. a better way to represent the particular cam profile one is peddling would be to offer a gragh of the profile in relationship to a stock profile or competitors profile.this would be a more accurate gauge for the consumer as to what he or she is buying!</TD></TR></TABLE>Well said. I assume we are talking about RS Machine when we say RS Cams. I'm in there all the time and never have seen a cam grinder in there. Anyone can say they are a cam grinder (I've built custom cams at Ruben's Cams) but unless you work with cam profiles all the time, I don't think you are doing anyone a real service.
Old Jul 5, 2003 | 06:03 PM
cleanEG's Avatar
Default Re: (earl)
Yeah, more than likely they have someone else manufacuturing the cams. I would like to compare these cams (non vtec eliminator) with other cams on the market with my setup, but unfortunately I dont have the resources to perform such a test. At any rate, they are making more power than my ITR cams throughout the powerband and for the price I would reccomend them to anyone...
Old Jul 5, 2003 | 11:59 PM
riceboy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by omniman &raquo;</TD></TR><TR><TD CLASS="quote">a better way to represent the particular cam profile one is peddling would be to offer a gragh of the profile in relationship to a stock profile or competitors profile.this would be a more accurate gauge for the consumer as to what he or she is buying!</TD></TR></TABLE>
Thats the way it should be, everyone is always concerned with numbers, flanks don't ever get the credit that the side by side graph would.
Old Jul 7, 2003 | 11:31 AM
Rocket's Avatar
Default Re: (earl)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by earl &raquo;</TD></TR><TR><TD CLASS="quote">These specs match the Web Cam we have been using for 2 years. </TD></TR></TABLE>
Not being confrontational Earl but there is no way you can grind the RS profile into the stock blank and have a adequate base circle.
About the soundest advice I can give anyone now is "listen to Omniman" he knows what he is doing. Period. I am talking practical knowledge about every part of the honda motor. Thumbs up to you Omniman.
Old Jul 7, 2003 | 03:59 PM
earl's Avatar
Default Re: (Rocket)
It was a very small base circle...probably too small and did affect the geometry somewhat. I agree that the only way to do it right is on new blanks
shant
134
Aug 14, 2006 05:01 PM
integGSR805
Feb 22, 2005 08:26 PM
^AnDre^
21
Dec 13, 2004 09:36 AM
AccSIR
Jan 5, 2003 10:40 AM
TRuST
Nov 9, 2001 12:24 PM
