Bearings for Eagle H-Beam Rods for GSR. HELP!!!!!!!
I have a set of Eagle H-Beam Rods for a GSR. I have the LETTER code off of the crank for the Rod Bearings. What number am I suppose to use to figure out which OEM Bearings to get for the rods???
Also, what should I Torque the Rods to?
where are you getting this info from? (for future reference)
Please give me facts, not a number out of head that you just remembered.
Thank You
Newbe
Thank You
Newbe
I used ACL bearing with my old eagle rods, my crank journal for the rod uses 3 green and 1 yellow with stock rods. Everything fits dead on specs, I just recently took the rods out and the bearing was still good as new.
Don't quote me on this, but, if you're using #2 as a references in matchin it with the codes on the crank, you'll fall dead on specs as well.
The Torque numbers on eagle rods bolts is 28 ft/lb
stan
stan
now i'm in a bit of a dilema becuz a friend of mine said that i'm suppose to use #3 as a reference to match the bearings. i checked all the papers/sheets that came with the rods but it did not have anything about the bearings.
i want to use OEM Honda bearings, this i'm sure of.
any HELP ANYONE??!!?
I am not too sure which number you can use for honda bearing, I know crower uses # 2. I doubt eagle will reference that. TTT to someone who had done this before
