Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
Harness set-up in question.
Old Jun 25, 2003 | 07:15 AM
Mike D's Avatar
Default Harness set-up in question.
Ok this is the temporary set-up until i gots cash to run real seats. Yay or Nay?
Mike
Old Jun 25, 2003 | 07:24 AM
.RJ's Avatar
.RJ
Default Re: Harness set-up in question. (Mike D)
You racing your garage?
Sweet... Looks good though, dont forget the sub belt.
Old Jun 25, 2003 | 07:33 AM
JustChou's Avatar
This brings new meaning to "you can sleep in your car, but you can't race in your house."
Old Jun 25, 2003 | 07:36 AM
GSpeedR's Avatar
Default Re: Harness set-up in question. (JustChou)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JustChou &raquo;</TD></TR><TR><TD CLASS="quote">This brings new meaning to "you can sleep in your couch, but you can't race in your house."</TD></TR></TABLE>
You can sleep in your "car"? Or did I miss the damn joke?
Edit: Haha you fixed it...
Old Jun 25, 2003 | 07:49 AM
Georgethefierce's Avatar
Default Re: Harness set-up in question. (.RJ)
YO that thing would look MAD tight w/ a big Body kit and aluminum wing
Oh yeah don't forget the DUBS......
all kidding aside your garage floor is cleaner than my living room carpet.
Crack Monkey's Avatar
With that one-sided headrest, you should try to find a H-strap to connect the two shoulder belts.
Old Jun 25, 2003 | 07:56 AM
SPiFF's Avatar
Default Re: Harness set-up in question. (Crack Monkey)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Crack Monkey &raquo;</TD></TR><TR><TD CLASS="quote">With that one-sided headrest, you should try to find a H-strap to connect the two shoulder belts.</TD></TR></TABLE>
Yes and also if you don't care about that seat, cut a slit in the bottom cushion to pull the anti-sub through.
Old Jun 25, 2003 | 08:14 AM
Mike D's Avatar
Default Re: Harness set-up in question. (SPiFF)
would it be ok to mount the sub belt back far and run it through the opening between the bottom cushion and the seat back? Or is cutting a slit the only way?
Yeah i got the dubs in the mail. Now i just got to find a way to mount the wing.
Mike
Old Jun 25, 2003 | 08:21 AM
urbanlegend21's Avatar
New User
that will NOT work without a harness bar
Old Jun 25, 2003 | 08:53 AM
civicrr's Avatar
Default Re: Harness set-up in question. (urbanlegend21)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by urbanlegend21 &raquo;</TD></TR><TR><TD CLASS="quote">that will NOT work without a harness bar</TD></TR></TABLE>
The laps need to pull down & back on your hips (pelvic girdle area) to work right. The sub belt is there to make sure the laps don't ride up. If you run the the lap bassackwards thru the cushions, it will cause damage to body parts & still won't work right. If you don't want to cut the seat, going forwards is better than back.
BTW, I have heard that many driving org. won't allow the 4 point because of the possiblity of pulling the laps up too far. They would rather have you use a 'stock' belt.
Old Jun 25, 2003 | 09:04 AM
Mike D's Avatar
Yeah i have a autopower 4 pt. with the harness bar.
Mike
cmerce
21
Dec 6, 2008 09:11 PM
eg6vtec1
Feb 11, 2008 06:21 PM
beedoublejay
11
Mar 26, 2006 10:07 PM
barefootbilly
10
Mar 30, 2004 06:39 AM
keithv
11
Jun 18, 2003 04:34 AM
