Is the si thermostat same as b16 thermostat?
Old Jun 25, 2003 | 06:48 AM
model x's Avatar
Default Is the si thermostat same as b16 thermostat switch?
My fan isn't coming on in my b16 and I now have a tiny rad so has anyone used the switch from an Si?
Old Jun 25, 2003 | 07:35 AM
raene's Avatar
Default Re: Is the si thermostat same as b16 thermostat switch? (model x)
Are you talking about the thermostat or the fan switch in the back of the block? Please clarify.
The thermostats are different. You need a del Sol VTEC piece for your B16A. The thermoswitch on the back of the block (the fan switch, whatever you want to call it) is the same. I'm using an Si thermoswitch right now.
Old Jun 25, 2003 | 10:17 AM
model x's Avatar
Default Re: Is the si thermostat same as b16 thermostat switch? (raene)
Ya, I ment the fan switch. But I couldn't edit my topic.
Thanks
b16_teggy
Apr 22, 2007 09:05 PM
Nameless Warrior
16
Dec 13, 2006 07:19 AM
turboxsi
Feb 25, 2005 09:45 AM
riceball777
Apr 29, 2003 12:40 AM
