need help, check engine light
Old Jun 24, 2003 | 10:17 PM
si foo's Avatar
Default need help, check engine light
Hey guys don't no what's wrong with my 93 gsr. I was drving on the highway fine, when I got off the highway, I gave it a push (redline). 1st was fine then in the middle of 2nd the engine stalled alittle, then the check engine light came on. At the light the car idle at 1,500-1,800 rpm and there was some odor. The car drove fine all the way back home. I shut off the motor and start it back up, same thing check engine light and idling at 1,500 rpm. What is the problem i can figure it out. Oh yeah the motor was very hot the fan was kicking on and off alot, but it's not overheating. Thanks for any ideas. Need it asap...
B17a1 with Skunk2 IM, ITR thottle body....
Old Jun 24, 2003 | 11:42 PM
IN VTEC's Avatar
Default Re: need help, check engine light (si foo)
Pull the code(s) and remember it/them.
Reset the ECU. If code is recurring, then diagnose further.
Old Jun 24, 2003 | 11:53 PM
si foo's Avatar
Default Re: need help, check engine light (IN VTEC)
how do i pull the code on the car?
Old Jun 25, 2003 | 05:50 AM
StyleTEG's Avatar
C-speed racing has a good tutorial and list of codes
http://www.c-speedracing.com/faq/06.php
Basicly you jumper the harness under the glove compartment, turn the ignition key, and count the long/short flashes of the CEL light.
Old Jun 25, 2003 | 07:10 PM
kkim's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by si foo &raquo;</TD></TR><TR><TD CLASS="quote">how do i pull the code on the car?</TD></TR></TABLE>
so... what was the code?
G. Man
12
Feb 25, 2011 06:13 PM
91b16acrx
Apr 20, 2008 09:20 AM
Teamdiesel
Apr 22, 2007 07:56 AM
lowered94accord
Mar 16, 2007 08:27 AM
greenDC2
Feb 25, 2005 09:41 AM
