brake bleeding materials
Old Jun 24, 2003 | 10:05 PM
deviant1's Avatar
Default brake bleeding materials
whats needed to bleed my brakes on my civic? besides the fluid. i was wondering where to buy the hose to use on the nipples, or what size. or is there any kind of hose around the house i could use? TIA
edit- i am changing the old fluid out and putting in new/better fluid. not sure if this makes a difference but just to let you know. any how-to's on replacing your brake fluid? -edit
Old Jun 25, 2003 | 12:09 AM
Mr. Choi's Avatar
New User
Default Re: brake bleeding materials (deviant1)
im not 100% sure on this but you will need a 10mm tubing wrench for the front and a 8mm for rear. you can use a box end wrench too. the tube i think its a 5/8 inch ID (inner diameter) you can get that at like orchard or home depot.
anyone correct me if im wrong
Old Jun 25, 2003 | 12:12 AM
aw1234dude's Avatar
Default Re: brake bleeding materials (Chois i-VTEC)
Other then the wrenches, if theres a kragen schucks or checkers or a autozone go in and pick up a thing called a bleedomatic. It makes changing fluid and bleeding very easy.
Old Jun 25, 2003 | 01:58 PM
deviant1's Avatar
Default Re: brake bleeding materials (aw1234dude)
anyone know for sure what size hose to use? for a civic
Old Jun 25, 2003 | 01:59 PM
976's Avatar
976
New User
Materials needed:
A friend
8 mm wrench
Vacumm hose
Use search to find the best technic, I'm too lazy to explain.
Old Jun 25, 2003 | 02:04 PM
andrew dc's Avatar
Default Re: brake bleeding materials (w00t!)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by w00t! &raquo;</TD></TR><TR><TD CLASS="quote">Materials needed:
A friend
8 mm wrench
Vacumm hose
Use search to find the best technic, I'm too lazy to explain.</TD></TR></TABLE>
10mm????
Old Jun 25, 2003 | 02:05 PM
deviant1's Avatar
thanks for the help. not looking for the technique tho. just the correct size hose that connects to the brake nipples.
no one knows the exact size?
Old Jun 25, 2003 | 02:10 PM
ejprimo's Avatar
A friend
8 mm wrench
Vacumm hose
i did it myself. i just leave the hose in the bottle sumerged in brake fluid so no air gets in the lines.
Old Jun 25, 2003 | 02:33 PM
deviant1's Avatar
Default Re: brake bleeding materials (ejprimo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ejprimo &raquo;</TD></TR><TR><TD CLASS="quote">
i did it myself. i just leave the hose in the bottle sumerged in brake fluid so no air gets in the lines.</TD></TR></TABLE>
can someone clear this up for me? you put the hose in the brake fluid bottle? or a clear container? if you drain the fluid into a clear container, can you put this fluid back into the MC? if you are flushing out the old fluid and putting in new/better fluid, then you would have to throw away the fluid that is being drained into the container correct? and when the new fluid is draining into a new container, when it is purely the new fluid, can you put in back into the MC to flush the other brakes?
correct size of tubing/hose anyone? or do i just walk into home depot and grab whatever vacuum hose they have? im sure there are different sizes
Old Jun 25, 2003 | 02:45 PM
andrew dc's Avatar
go to an auto parts store.. there are bleading kits with various sized nipples.... like 3-5 bucks.. I personally got a 1 man bleeding kit, since I dont have friends.
Old Jun 25, 2003 | 02:49 PM
976's Avatar
976
New User
Default Re: brake bleeding materials (CRX25)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRX25 &raquo;</TD></TR><TR><TD CLASS="quote">
10mm????</TD></TR></TABLE>
Yup it is 10mm, sorry...
Old Jun 25, 2003 | 03:35 PM
deviant1's Avatar
is that inner diameter?
Old Jun 25, 2003 | 03:48 PM
976's Avatar
976
New User
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by deviant1 &raquo;</TD></TR><TR><TD CLASS="quote">is that inner diameter?</TD></TR></TABLE>
When you bleed your clutch you bleed from the bleed screw, the screw has a hex style place to put your wrench, you use a 10mm wrench to lossen and tighten this bleed bolt. So outer diameter hex screw...
Old Jun 25, 2003 | 04:19 PM
Paranoid Android's Avatar
You DON'T need a friend.
Check out this badboy.
You can pick it up in the Best Buys section for...5 bucks I think?
It negates the purpose to having a friend, and much unwanted frustration.
Edit-BTW it's called a SpeedBleeder.
Old Jun 25, 2003 | 04:25 PM
Synergy001's Avatar
Default Re: brake bleeding materials (Paranoid Android)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Paranoid Android &raquo;</TD></TR><TR><TD CLASS="quote">You DON'T need a friend.
Edit-BTW it's called a SpeedBleeder.</TD></TR></TABLE>
I have that also....they work GRRRREEEEAAATT!!
Old Jun 25, 2003 | 08:19 PM
EARLdaSQUIRREL's Avatar
official honda whore
i heard those speed bleaders tend to leak over time
Old Jun 25, 2003 | 08:33 PM
DOHCtorTHRUST's Avatar
Default Re: (coptzer)
how does the speed bleeder work? do you have to pump it until the fluid pushes the spring to let loose the fluid?....
Old Jun 30, 2003 | 11:36 AM
96IntegraLS4DR's Avatar
Default Re: (DOHCtorTHRUST)
This should answer your question.
https://www.speedbleeder.com/
you can get it half off on Ebay if you look hard and be patience.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DOHCtorTHRUST &raquo;</TD></TR><TR><TD CLASS="quote">how does the speed bleeder work? do you have to pump it until the fluid pushes the spring to let loose the fluid?....</TD></TR></TABLE>
Lucman
Dec 13, 2008 10:35 AM
kommon_sense
Jan 4, 2005 11:46 AM
wc
Aug 11, 2004 08:00 AM
LX4CYL
Jan 11, 2004 11:45 AM
chadmasterc
Nov 3, 2003 07:44 AM
