cylinder #1 is next to the dist. right?
i know i am a dumb *** and every one is going to look down at me. but i just kinda forgot
is it next to dis or next to cam gear?
next to cam gear is #4 right?
is it next to dis or next to cam gear? next to cam gear is #4 right?
so when i am timming my car, i hook it around # one. the t-belt side, not the dist. side.
when i am timming my car, and hook it around the one closest to the dist. the timming is closer to correct, and when its hook around the wire closest to the belts its off! any ideas?
I use the one by the distributor for cylinder one...
but looking at my factory service manual, it's actually the one by the belts... at least that's the wire they hook up to in the picture for doing timing...
Jung
Jung
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jung4g »</TD></TR><TR><TD CLASS="quote">I use the one by the distributor for cylinder one...
from distributor it goes 4,3,2,1
from belts it goes 1,2,3,4
so number one is on the belt side
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by matt j »</TD></TR><TR><TD CLASS="quote">
so number one is on the belt side</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VTgringo »</TD></TR><TR><TD CLASS="quote">how many honda guys does it take to find cylinder number 1? hehe</TD></TR></TABLE>
I think your phase is lacking something.. it should really read
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VTgringo »</TD></TR><TR><TD CLASS="quote">how many honda-TECH guys does it take to find cylinder number 1? hehe</TD></TR></TABLE>
To answer the initial question though...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote »</TD></TR><TR><TD CLASS="quote">so when i am timming my car, i hook it around # one. the t-belt side, not the dist. side.
when i am timming my car, and hook it around the one closest to the dist. the timming is closer to correct, and when its hook around the wire closest to the belts its off! any ideas?</TD></TR></TABLE>
Your timing is off and you need to rotate your distributor and check it again until it's right. Make sure you have disabled your electronic timing advance before you do any timing adjustments.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Turbo12acer »</TD></TR><TR><TD CLASS="quote">Final answer: from belt is 1 so it should look liek this
dizzy (4) (3) (2) (1) belts</TD></TR></TABLE>
hahaha add another member to the list hahahaa
we have pretty much killed that horse with which way it goes
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by I8ayellowcrayon »</TD></TR><TR><TD CLASS="quote">There you go. Pictures are good. Just curious though, I know everyone says to find TDC out of #1, but #1 and #4 are in the exact same position in stroke.....</TD></TR></TABLE>
Yeah I want to know? Learning to do timing belt on a CRX Si.
From: hittin corners so hard you can taste my rims..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by I8ayellowcrayon »</TD></TR><TR><TD CLASS="quote"> Pictures are good. Just curious though, I know everyone says to find TDC out of #1, but #1 and #4 are in the exact same position in stroke.....</TD></TR></TABLE>
Your right on the piston possition.. but, for the most part, your right.. but when adjusting valves... TDC is essential. if #1 is TDC the Exh valve on 4 is still open.. or however that works... ide have to play wiht a set of cams, and figure it out..
so.. other than pistons being at the top.. the other half of it is valves.. and as we all know.. the cam controlls the valve
tuna-can
Oct 14, 2009 05:53 AM
redpeppers
Jul 23, 2005 12:10 AM
