do these slicks suck?????
Old Jun 24, 2003 | 08:56 PM
92hybridhhatch's Avatar
From: from Brooklyn NY U.S. Army recruiter in Holyoke, MA, USA
Default do these slicks suck?????
I just purchased a set of M/T's 24 x 4.5 x 15 and I will still sucking getting off the line, I was just reading around here and I saw that most people are recommending less than 10 psi,I was running 12 so maybe that was a factor but are the tires just not really great to begin with? heres my setup , 92 hatch , b16a2 I/H/E and a 50 shot on a stock clutch , Guys I was still chirping in 3rd , any opinoions on these tires or prior experience ?!?!??!?!?!
Old Jun 24, 2003 | 09:11 PM
Default Re: do these slicks suck????? (92hybridhhatch)
here are the numbers I pulled
R/T....609 1.131 .637
60......2.496 2.489 2.271
330....6.551 6.575 6.240
1/8.....9.787 9.882 9.483
330.....76.51 74.06 76.81
1000....12.534 12.707 12.220
1/4......14.859 15.108 14.589
MPH....97.12 94.13 97.20
Old Jun 24, 2003 | 09:14 PM
Arturbo's Avatar
Better than steak
25 Year Member
Get some M&H.
Old Jun 24, 2003 | 09:17 PM
hybrid901's Avatar
Default Re: do these slicks suck????? (Arturbo)
4.5?
Old Jun 24, 2003 | 09:27 PM
4piston's Avatar
Default Re: do these slicks suck????? (hybrid901)
I hope you mean 24x8.5. Those are way too big for the power you have and a stock clutch. Even a 20 inch slick would eat that stock clutch on a 50 shot.
Old Jun 24, 2003 | 09:42 PM
AllMoToRB18c's Avatar
Default Re: do these slicks suck????? (4piston)
first thing i would do is replace the clutch..stock clutch wont hold up wit slicks...i would put my tire pressure at 6or7 psi wit slicks.....i wouldnt really go that big of a slick but since u alrdy have them use em...wit only a 50 shot i would of gotten a 22 instead of a 24.5..and maybe ur not launching the car at high enough rpms..try launching it at like 6500 rpm and slip the clutch...dont pop it!
Old Jun 24, 2003 | 09:44 PM
Default Re: do these slicks suck????? (AllMoToRB18c)
and 15 inch is a big rim...u should get 13's..that would be a good set up for what ur trying to do
Old Jun 24, 2003 | 11:54 PM
ExospeedAMcrx's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92hybridhhatch &raquo;</TD></TR><TR><TD CLASS="quote">I just purchased a set of M/T's 24 x 4.5 x 15 </TD></TR></TABLE>
Are you sure about that size?
those are skinnies.
Old Jun 25, 2003 | 04:31 AM
PM-Performance's Avatar
Default Re: do these slicks suck????? (exospeedAMcrx)
yea that wiodth sounds too skinny, you cant get a good contact patch wit those
Old Jun 25, 2003 | 05:17 AM
paulzy's Avatar
Default Re: do these slicks suck????? (itr206)
I say he's not making the power....look at those trap speeds. I'd check your bottle pressure
Old Jun 25, 2003 | 07:49 AM
Red CiViC Hatch's Avatar
Default Re: do these slicks suck????? (Paul_Vang)
whats up with the 60ft.......
Old Jun 25, 2003 | 08:36 AM
badCRX's Avatar
New User
Default Re: do these slicks suck????? (Red CiViC Hatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Red CiViC Hatch &raquo;</TD></TR><TR><TD CLASS="quote">whats up with the 60ft.......</TD></TR></TABLE>
I thought the same. I am thinking to use a 22" slick and run about 8-10psi of air pressure in them.
Old Jun 25, 2003 | 09:07 AM
methred_92's Avatar
I pulled 2.3 second 60' times with a D16Y7 with I/H/E and Z10 bars on 195/60/14 azenis.
just giving ya something to compare with
Old Jun 25, 2003 | 10:15 AM
flip1199's Avatar
Default Re: do these slicks suck????? (methred_92)
your running skinnies, get real slicks. How wide is 4.5??Isn't that the size of a spare??
Old Jun 25, 2003 | 10:33 AM
essinem4130's Avatar
My best 60' on my 205/50/15 cheap Brand-X tires was 2.2... And this was at LACR no less. Those slicks are way too big for your car. 20+/-" for a mild NA car are perfect, 24+" slicks are way too tall.
Old Jun 25, 2003 | 01:29 PM
slowdx's Avatar
i hit 2.1's on 13 inch stock no name tires lol way to be running on tires the size of spares.....
Old Jun 25, 2003 | 03:46 PM
Speedworks801's Avatar
Default Re: do these slicks suck????? (slowdx)
Do a small burnout in the water box and then a big one after. Hold the E-brake up with the tires in the water box to help you hold the car still. Make sure you smoke the tires for a minimum of 3-5 seconds. The rubber should look like a used pencil eraser if you know what I mean. 12psi should still net you some good times. Stock clutch may be slipping though.
Good Luck!
Old Jun 26, 2003 | 04:09 AM
1 2 NV's Avatar
everyone is right, those tires whether u stated the right size or not are way too big for a stock setup. u need to drop down to 22s if not go to 20s for a B16 w/NOS setup. u dont have any power to pull 24" tires.
Old Jun 26, 2003 | 08:13 AM
AllMotorDC2's Avatar
24's are way too big for the power you're producing. Try some 22's or even 20's.
lilo_goki
May 18, 2007 12:28 PM
EdBoon
Jul 28, 2005 11:51 AM
boosted1993
Aug 17, 2003 09:34 AM
oldguy
Dec 5, 2002 07:57 PM
