engine drop-in question.
Old Jun 24, 2003 | 07:17 PM
TrickHonda98's Avatar
Default Vtec engine drop-in question.
this is just a quick little question. am I able to drop a B16A(VTEC) into a '95 civic coupe? and what new harnesses, mounts, Etc. would I need If Possible?
Old Jun 24, 2003 | 07:18 PM
Paranoid Android's Avatar
Default Re: engine drop-in question. (TrickHonda77)
go here.
https://honda-tech.com/zerosearch
Old Jun 24, 2003 | 07:28 PM
Default Re: engine drop-in question. (Paranoid Android)
I still couldn't find anything.
Old Jun 24, 2003 | 07:32 PM
Pho Real's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TrickHonda77 &raquo;</TD></TR><TR><TD CLASS="quote">I still couldn't find anything.</TD></TR></TABLE>
hahahahah, you sure? nothing?
Old Jun 24, 2003 | 07:36 PM
Default Re: engine drop-in question. (Pho Real)
no. nothing, all I see is stuff about a guy converting his civic to AWD, and whole lotta other crap that a bit useful though
Old Jun 24, 2003 | 07:40 PM
I just went through everything and no luck. and I was specific.
Old Jun 24, 2003 | 07:46 PM
poison's Avatar
Default Re: Vtec engine drop-in question. (TrickHonda77)
Just to be advisable, read on how to use the search. There are millions of threads on this topic and swapping in a B series into 92-95 Civic's, and even 96-00 Civics.
You can use your stock mounts, but will need a 99-00 Si reare tranny bracket.
As for the wiring, mainly depends on what year/obd the engine is. If you get a 2nd Gen B16A swap, then you can use your factory harness, wire up Knock Sensor to D3, and you're done -- using the P30 ECU.
If you are attempting to swap in a 1st Gen B16A, I would steer away from it as it's OBD0 and you'll need to convert several things like the plugs and such to OBD1.
As for the B16A2 OBD2 motor, I would recommend you use a 96-00 Integra GSR harness, it'll be mainly all plug and play, you will just need to wire up VTEC (if your coupe is a DX), and knock sensor.
IntegraGSR-Turbo
Feb 27, 2007 12:08 AM
silentdaredevil2
Oct 8, 2006 09:07 AM
turtles_civic
Apr 2, 2006 12:21 PM
anotheredhatch
Welding / Fabrication
21
Dec 19, 2004 09:36 AM
DsCivicEx
Dec 4, 2003 02:15 PM
