general q's about b16 in ek hatch...
Old Jun 24, 2003 | 07:14 PM
2000CX's Avatar
Default general q's about b16 in ek hatch...
so i have had my swap for about 3 months now. all along i have been running it with CEL because of my secondary o2 not being there. could i have caused any damage by doing this? is there any way it could be running lean? i just but an exhaust(kteller 2.5" with magnaflow cat and straight thru muffler) snd have since noticed what seems to be less power. then last week i washed down the motor and noticed some bogging down but then went away. something just doesn't feel right...any ideas where to start looking?
Old Jun 24, 2003 | 07:37 PM
2000CX's Avatar
Default Re: general q's about b16 in ek hatch... (2000CX)
no one has an idea of where to start?
Old Jun 24, 2003 | 07:40 PM
allmtr's Avatar
well with a cel on ive noticed that the engine will put itself in safe mode and richen itself, or retatd itself... something like that. there is no damage, just a slight power loss.
Old Jun 24, 2003 | 07:41 PM
chad's Avatar
Moderator
fix the CEL first....
all you have to do is go to a muffler shop and have them put an o2 bung on your cat or your high flow cat.....or buy a cat with a second o2 hole....which i have...im if you are interested....
ciRcuitJerk's Avatar
jus f0 dekarayshunZ
Default Re: general q's about b16 in ek hatch... (allmtr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by allmtr &raquo;</TD></TR><TR><TD CLASS="quote">well with a cel on ive noticed that the engine will put itself in safe mode and richen itself, or retatd itself... something like that. there is no damage, just a slight power loss.</TD></TR></TABLE> not all cel cause your ecu to go into limp mode...i dont think the o2 sensor is one of them
Old Jun 24, 2003 | 07:43 PM
allmtr's Avatar
Default Re: general q's about b16 in ek hatch... (ciRcuit_ _ _)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ciRcuit_ _ _ &raquo;</TD></TR><TR><TD CLASS="quote"> not all cel cause your ecu to go into limp mode...i dont think the o2 sensor is one of them</TD></TR></TABLE>
yeah... i think your right on that one. i know my knock sensor problem did that.
Old Jun 25, 2003 | 05:07 AM
2000CX's Avatar
i had the o2 bung added but i am a little nervous about the actual wiring. anyone know a good place for reliable pinouts for an 00 b16? also if anyone has done this where did you run the wiring? the si's have a hole in the floor board right near the shifter but i do not think my cx hatch has that hole...i'm thinking somewhere in the firewall...will the length of the wire effect the signal at all?
Old Jun 25, 2003 | 07:54 AM
2000CX's Avatar
up for more ideas...
Old Jun 25, 2003 | 06:13 PM
2000CX's Avatar
eh...once more...
Old Jun 25, 2003 | 07:07 PM
chad's Avatar
Moderator
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2000CX &raquo;</TD></TR><TR><TD CLASS="quote">eh...once more... </TD></TR></TABLE>
FIX CEL then get back to us....fix one problem at a time!!!
danielm3
Welding / Fabrication
18
Sep 29, 2008 07:34 PM
mystikz2002
Sep 23, 2005 06:20 PM
AintegraA
Oct 7, 2004 06:41 PM
98dxhatch
Sep 24, 2003 02:32 PM
ajchen
Mar 26, 2003 08:23 AM
