B20 Vtec into an EG
yeah your right but i just needed a quick answer to a quick question and bassically i just need to know what drive shafts i should use or if i need to swap them out too an wanted to know what ecu i should run, Hybridhackbatch you dont gotta be a dick about it
everything is the same as a b16 swap.unless i think it is a 88-91 then the same axle rules apply. Y1 = 90-93 inners, 89 outers. S1 J1 = 90-93 inners and outers. please correct me if i am wrong.
EDIT ok it is an EG. type r axles, SiR2 axles. 99-00 Si axles.
If your asking this broad question, chances are that you shouldn't attempt it in the near future.
(you would need the following: B20 Block, Dohc Vtec head, tranny, wiring harness, shift linkage, axles, ecu, motor mounts, oil line, and A LOT more miscellaneous stuff, another thing, if you want to know what needs to go in, you need to provide a bit more information then right now its non vtec. Do you have a swap already? I doubt it but you could reply and give us the skinny if you need a complete B series changeover or just the longblock info.)
Lovin_My_E.G[G]
15
Nov 11, 2009 08:33 PM
