saturated injectors in an OBD-0 car? (peak and hold)
would saturated injectors work in an OBD-0 car? with the resistor box removed of course...asking if it would work because OBD-0 ecu doesn't control the injectors like OBD 1+ ecus
any help would be great
it would. thats what i have in my car.. the ecu (obd1 and non obd) both control the injector. only thing is that the resistance in peak and hold is lower, so they use the resistor box so it wouldnt heat up as bad. saturated injectors have a higher resistance already built in. so a resistor box isnt necessary.
e jay one
Aug 6, 2005 02:48 PM
