91 civic throttle sticks
Old Jun 24, 2003 | 05:26 PM
itr1235's Avatar
Default 91 civic throttle sticks
i`ve tried greasing all connection but to no avail, if i tap on the gas pedal the idle drops !!!! help!!!!
Old Jun 24, 2003 | 05:44 PM
E-AT_me's Avatar
Default Re: 91 civic throttle sticks (itr1235)
try spraying in some throttle body cleaner. the butterfly may be getting stuck.. if that doesn't work, a new cable's only 25 bucks or so..
Old Jun 24, 2003 | 05:47 PM
FourthGenHatch's Avatar
My old one used to do that. Make sure the spring on it is good because if they aren't strong enough it will stick open.
Hcivic88's Avatar
Default Re: 91 civic throttle sticks (Rexman)
try spraying some wd-40 on the throttle cable linkage too, where the throttle body connects to the throttle cable. it may be getting stuck there too.
Old Jun 24, 2003 | 08:26 PM
91civicEX's Avatar
mine did that too after the mpfi swap. try loosening the throtle cable a little. for a while i had to pull on my gas pedal with my foot to get it to drop.
Old Jun 25, 2003 | 06:40 AM
itr1235's Avatar
Default Re: (91civicLX)
will try all suggestions
Old Jun 25, 2003 | 07:00 AM
Brandon Clifton's Avatar
Default Re: (itr1235)
also, check the vacuum line to the dashpot (if your car is so equipped). This, in combination with the metal clips that route the throttle cable and the weak throttle spring, caused the same problem. I ended up zip-tying the cable loosely to the factory cable routing clips and adding an extra spring to the throttle cam to return it. Oh well- it works now.
Old Jun 25, 2003 | 07:13 AM
YumVTEC's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91civicLX &raquo;</TD></TR><TR><TD CLASS="quote">mine did that too after the mpfi swap. try loosening the throtle cable a little. for a while i had to pull on my gas pedal with my foot to get it to drop.</TD></TR></TABLE>
ditto... i wonder if it's a problem using the longer DX/Std throttle cable with the MPFI intake manifold and tb.
Old Jun 25, 2003 | 08:31 AM
tysf's Avatar
happened to me in the middle of winter. like -20 degrees just started my car and after i gave it some gas to back up the cable just stuck.... shot straight to 7000 with the engine dead cold before i turned the key off.
happened like 3 more times this winter. hasnt happened since it warmed up though, and the d15 is still going strong
Old Jun 25, 2003 | 08:37 AM
Default Re: (YumVTEC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by YumVTEC &raquo;</TD></TR><TR><TD CLASS="quote">
ditto... i wonder if it's a problem using the longer DX/Std throttle cable with the MPFI intake manifold and tb.</TD></TR></TABLE>
You have to reroute the DX/STD cable for it to work, I've seen people basically run it and wrap it around the engine mount once and then to the throttle body. When I did my swap I got a throttle cable from an Si at the junkyard, screw ghetto rigging stuff up.
Old Jun 28, 2003 | 08:51 PM
91civicEX's Avatar
ive got the ghetto rigged zip tied dpfi throttle cable
Old Jun 28, 2003 | 11:10 PM
THEYARDMAN's Avatar
From: The Grass is allways Greener on the other side
clean that ****
smc1118
May 5, 2014 04:55 AM
theresyourproblem
Oct 4, 2007 09:28 AM
c r x_s i
26
Apr 6, 2007 09:47 PM
91da9ls
Jan 29, 2007 04:00 AM
rasta420
15
Mar 15, 2003 05:38 AM
