distributor question
Old Jun 24, 2003 | 02:31 PM
91hatch_on17's's Avatar
Default distributor question
Can I use a LS distributor on a vtec motor? I heard of people modifying their LS dizzy to run vtec. Does anybody know how to do this? Thanks.
Forgot to say that it will be going on a B16 converted to OBD1.
Modified by 91hatch_on17's at 11:51 PM 6/24/2003
Modified by 91hatch_on17's at 4:43 AM 6/25/2003
Old Jun 24, 2003 | 07:43 PM
Default Re: distributor question (91hatch_on17's)
anyone?
Old Jun 24, 2003 | 08:07 PM
pokemon's Avatar
Um if you mean use an LS dizzy on a b16a yes, you can't make your dizzy vtec though. Motors have vtec not dizzy's.
Old Jun 25, 2003 | 06:07 AM
Default Re: (pokemon)
so if I use the LS dizzy, vtec will still work? correct me on this one if im wrong
Old Jun 25, 2003 | 10:27 AM
jung4g's Avatar
Default Re: (91hatch_on17's)
YES Vtec will still work. The distributor does not control vtec, the ECU does. Any B-series distributor (technically) should work fine...
Jung
Old Jun 25, 2003 | 11:02 AM
Default Re: (jung4g)
ok cool...thanks guys to HT
Old Jun 25, 2003 | 09:24 PM
1stealthls's Avatar
u will have to cut one of the legs of and make sure it is a 2nd gen ls dizzy
non obd
Old Jun 25, 2003 | 10:26 PM
HandCommand's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jung4g &raquo;</TD></TR><TR><TD CLASS="quote">YES Vtec will still work. The distributor does not control vtec, the ECU does. Any B-series distributor (technically) should work fine...
Jung</TD></TR></TABLE>
The U.S. 90-91 Integra LS dizzy should work with modification to the mounting points. The 92+up Integra will not work since they are OBD1 or OBD2.
I say convert to OBD1 now and be done with it. Now if you ever need a distributor down the road, you could always order one from your local parts store. OBD1 DOHC VTEC distributor.
I encourage my customers to go OBD1 when I perform their swaps. But for those that dont or dont have the extra money, I warn them about the rare, and fail prone OBD0 DOHC Vtec Distributors that was not offered here in the U.S.
Rigginit
Dec 26, 2009 09:57 PM
D-rush08
Sep 7, 2006 10:08 AM
Speed94
Mar 18, 2005 08:19 PM
Racer338
Dec 11, 2003 11:16 AM
Audi A4
Sep 15, 2003 09:26 AM
