broke a bolt head
when reinstalling my bumper this past weekend I twisted the head off one of the bolts that holds the bumper on the bottom. Most of the bolt is still threaded into the hole.
I tried drilling it out (broke 2 drill bits), and I tried a bolt extractor (which broke as well in the hole that I drilled...
so Im set back even further than square 1 because the extractor is made of harder material than the bolt was...)
So what do I do now? Should I take it to a machine shop and have them drill the whole thing out, making it larger and then just rethread? Or just **** it and drive it around w/ only 1 bolt holding it? It feels pretty solid...
so Im set back even further than square 1 because the extractor is made of harder material than the bolt was...)So what do I do now? Should I take it to a machine shop and have them drill the whole thing out, making it larger and then just rethread? Or just **** it and drive it around w/ only 1 bolt holding it? It feels pretty solid...
Just drill a new hole in a new location next to the fucked one and use a sheet metal screw to hold it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Nextekhatch »</TD></TR><TR><TD CLASS="quote">who needs a bumper anyway? Id just drill a hole next to it, or learn to do it old school and reenforce it with some zip ties.</TD></TR></TABLE>
unfortunately alot of my boys including me have had to use this trick, but it works and is unoticeable
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pdiggitydogg »</TD></TR><TR><TD CLASS="quote">bump...anyone else?</TD></TR></TABLE>
what else do you want? You already failed miserably at trying to take the bolt out.
Its time to go another route.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tonyXcom »</TD></TR><TR><TD CLASS="quote">
Its time to go another route.</TD></TR></TABLE>
dont be a punk *** bitch dude...
Im puttin the **** in this weekend...new hole, threaded and bolted down
(sheet metal screw would rust in less than 3 days in michigan)
get a stainless screw then cross threadin bolt *** bitch.
Flux
Nov 20, 2006 06:55 AM
redm3turbo
10
Jul 20, 2006 01:36 PM
