anyone upgraded throttle body on d-series
Old Jun 24, 2003 | 10:59 AM
goula SOS's Avatar
From: Kills Official Truck Quality Assurance Manager, USA
Default anyone upgraded throttle body on d-series
has anyone upgraded their throttle body on their d-series and if so what kind of improvements did u notice, is it worth doing
Old Jun 24, 2003 | 11:05 AM
chad's Avatar
Moderator
Default Re: anyone upgraded throttle body on d-series (goulasos)
just put a bseries tbody on my d16z....huge improvements...i aalso hogged out the intake manifold to match the 64 mm diameter
Old Jun 24, 2003 | 12:03 PM
goula SOS's Avatar
Default Re: anyone upgraded throttle body on d-series (chad)
the reason i was askin was because i found a gsr throttle body and the guy says it will match up to a d-series and i was just makin sure it will fit without any modification.
Old Jun 24, 2003 | 12:20 PM
chad's Avatar
Moderator
it will bolt up with no mods....but you will want to bore out the intake manifold
Old Jun 24, 2003 | 12:36 PM
drunknbass's Avatar
if i used any tb it wouldnt be a gsr
Old Jun 24, 2003 | 01:16 PM
goula SOS's Avatar
Default Re: anyone upgraded throttle body on d-series (drunknbass)
which tb would u recommend then
Old Jun 24, 2003 | 02:53 PM
Trial User's Avatar
I have a 68mm STR and I bored out the IM to match. Works nice. Very big throttle body and it eliminates the cold start circuit. That is not needed here because of the hot climate. I had to bore the IM quite a bit to match. The stock IM doesn't have much room for porting past 70mm.
toolbox21
Nov 27, 2008 10:21 AM
Elevorett
Apr 14, 2007 01:29 PM
allnaturalb16
Sep 26, 2006 02:09 PM
Fink2iCe
Aug 20, 2004 10:50 AM
