what springs did you get/have with your ground controls?
Old Jun 23, 2003 | 10:33 PM
NINJASPY's Avatar
Default what springs did you get/have with your ground controls?
my fronts are 700.250.350 (7inch long,2.5inch diameter, 350lbs)
rears are 180.64.44. 33/38 (7inch,2.5 dia. 250lbs)
I have a stock kit and I am wondering why they used metric on the rears and standard on the fronts... and what does the 33/38 mean?
And are 7inch springs front and rear standard on gc's? I thought rears were supposed to be 8in?
I am probably going to try 400-450lb springs in the rear soon.
Old Jun 24, 2003 | 05:13 AM
keithv's Avatar
Default Re: what springs did you get/have with your ground controls? (NINJASPY)
i am pretty sure my springs are 7" long. i know both the front and the rear are the same length in case i ever wanted to swap springs. i am currently running 450F/400R linear springs.
fyi, i think you have progressive springs in the rear. does the spring look like a progressive spring?
Old Jun 24, 2003 | 06:05 AM
slywfbpsi's Avatar
Default Re: what springs did you get/have with your ground controls? (keithv)
what shocks are you running with that setup?
Old Jun 24, 2003 | 06:31 AM
keithv's Avatar
Default Re: what springs did you get/have with your ground controls? (slywfbpsi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slywfbpsi &raquo;</TD></TR><TR><TD CLASS="quote">what shocks are you running with that setup?</TD></TR></TABLE>
koni yellows. hopefully next year they i can get them shortened and re-valved.
Old Jun 24, 2003 | 12:16 PM
slywfbpsi's Avatar
do they soak up the bumps in the roads? I've had tokico illimas but, my wife complained about her breasts hurting with them.
Old Jun 24, 2003 | 12:42 PM
keithv's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slywfbpsi &raquo;</TD></TR><TR><TD CLASS="quote">do they soak up the bumps in the roads? I've had tokico illimas but, my wife complained about her breasts hurting with them.</TD></TR></TABLE>
lol!
anyway, i call my car the "titty jiggler". i think you can figure out why i call it that. i don't daily drive my car, so the ride harshness doesn't bother me.
Old Jun 24, 2003 | 12:55 PM
slywfbpsi's Avatar
lol, I guess they'll just have to bounce then.
ef yu
17
Oct 6, 2010 11:46 AM
bopbop93030
Feb 22, 2010 11:17 PM
blkhondacivicSI
Suspension & Brakes
Aug 21, 2007 02:42 AM
b18c inside
Suspension & Brakes
10
Mar 20, 2006 10:14 PM
96hb
Apr 20, 2004 06:41 PM
