Seized Tein Ra's
Old Jun 23, 2003 | 03:44 PM
WOLFPACK's Avatar
Default Seized Tein Ra's
Haven't moved the perches on this set of Ra's for about a year, and now all 4 aren't going anywhere I don't understand cause they're full aluminum!!! Please help me with any thoughts or things I should try, Thx in advance
Modified by WOLFPACK at 5:34 PM 6/23/2003
Old Jun 23, 2003 | 04:07 PM
jdmjunky's Avatar
Default Re: Seized Tein Ra's (WOLFPACK)
can't see the pic but give tein a buzz..i'm sure they can help.
Old Jun 23, 2003 | 04:12 PM
jonas's Avatar
wd-40? we live in the same kind of climate.. and i was able to adjust my zeals with ease
go back to a&j and get those
Old Jun 23, 2003 | 04:27 PM
Big Phat R's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by WOLFPACK &raquo;</TD></TR><TR><TD CLASS="quote">Haven't moved the perches on this set of Ra's for about a year, and now all 4 aren't going anywhere I don't understand cause they're full aluminum!!! Please help me with any thoughts or things I should try, Thx in advance
Aluminum still oxidizes. Especially in rainy North Van.
You will probably have to remove all 4 coilovers from the car if they're seized that badly.
Old Jun 23, 2003 | 04:38 PM
WOLFPACK's Avatar
Default Re: Seized Tein Ra's (Big Phat R)
So i've tried using wd-40, a hammer/screw driver and alot of anger...but none of them will budge. Anyone have any other ideas??? Stupid Car
Old Jun 23, 2003 | 04:46 PM
YellowKahuna's Avatar
TEIN U.S.A.,inc.
7631 Somerset Blvd Paramount CA 90723
PHONE:1-562-633-7387
FAX:1-562-633-7291
see what they can do for you.
They have always helped me with my questions and problems
Old Jun 23, 2003 | 05:01 PM
WOLFPACK's Avatar
Default Re: Seized Tein Ra's (YellowKahuna)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by YellowKahuna &raquo;</TD></TR><TR><TD CLASS="quote">TEIN U.S.A.,inc.
FAX:1-562-633-7291
They have always helped me with my questions and problems </TD></TR></TABLE>
THX
Old Jun 23, 2003 | 05:18 PM
uNF$@#!'s Avatar
liquid wrench?
Old Jun 23, 2003 | 05:49 PM
WOLFPACK's Avatar
Default Re: Seized Tein Ra's (Soup ****)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Soup **** &raquo;</TD></TR><TR><TD CLASS="quote">liquid wrench?</TD></TR></TABLE>
tried it
Old Jun 23, 2003 | 06:06 PM
Asahi's Avatar
And a little heat.
Old Jun 23, 2003 | 06:23 PM
Tweakmeister's Avatar
Default Re: Seized Tein Ra's (Asahi)
I worked on some Apex'i WorldSports that were the same way.
Good luck...I ended up selling them for the owner.
Old Jun 23, 2003 | 06:56 PM
43MA's Avatar
Default Re: Seized Tein Ra's (Tweakmeister)
probrably gonna have to take off the top hat to relieve the spring tension on the lower perch.
good luck
Old Jun 23, 2003 | 07:31 PM
B18C5's Avatar
I unseized my HAs by removing them, putting them in a vice, spraying Liquid Wrench (then WD40 when I ran out), and heating them with a torch. Then I used the Tein wrench tool and hit it with a rubber mallet. I hit it and hit it and hit it and hit it. Then I sprayed it with more Liquid Wrench and hit it and hit it and hit it and hit it. Then I heated it with a torch, then I hit it and hit it and hit it and hit it.
It took about an hour per shock to remove them! Just be patient and they'll eventually come off.
Old Jun 23, 2003 | 07:33 PM
CunninLynguist's Avatar
Default Re: Seized Tein Ra's (B18C5)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18C5 &raquo;</TD></TR><TR><TD CLASS="quote">I unseized my HAs by removing them, putting them in a vice, spraying Liquid Wrench (then WD40 when I ran out), and heating them with a torch. Then I used the Tein wrench tool and hit it with a rubber mallet. I hit it and hit it and hit it and hit it. Then I sprayed it with more Liquid Wrench and hit it and hit it and hit it and hit it. Then I heated it with a torch, then I hit it and hit it and hit it and hit it.
It took about an hour per shock to remove them! Just be patient and they'll eventually come off.</TD></TR></TABLE>
Thats way to much damn work.
Send em to tein.
Old Jun 23, 2003 | 07:55 PM
WOLFPACK's Avatar
Default Re: Seized Tein Ra's (Scot project)
Thanks for all the support guys!!! Keep the ideas coming
Old Jun 24, 2003 | 12:34 AM
Saga's Avatar
Torch
Old Jun 24, 2003 | 12:42 AM
43MA's Avatar
is it cosher to put that much heat to them.
i would think the seals inside the damper would be damaged by that much heat.
Old Jun 24, 2003 | 01:51 AM
Default Re: Seized Tein Ra's (Steady)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Steady &raquo;</TD></TR><TR><TD CLASS="quote">is it cosher to put that much heat to them.
i would think the seals inside the damper would be damaged by that much heat.</TD></TR></TABLE>
they sure would. If worst comes to worst send them to tein.
Im sure they are more than willing to help.
who is happy that tein is 15 minutes away on a freeway .
Old Jun 24, 2003 | 04:03 AM
SEFIxCivic's Avatar
this probably isn't going to be helpful with your immediate problem, but in the future, you need to don't tighten the perches. lock them together by hand, and they'll never slip. most likely you won't have so much trouble the next time you need to adjust the height.
Old Jun 24, 2003 | 06:42 AM
00R101's Avatar
Default Re: Seized Tein Ra's (SEFI8LOxCivic)
4 words should fix your problem:
Ground Control or Koni
Stay away from that crappy JDM chit - (just kiddin')
But in all seriousness, the JDM stuff is kinda high priced and doesn't seem to have the workmanship, design or tuning to justify the price.
Old Jun 24, 2003 | 11:12 AM
43MA's Avatar
Default Re: Seized Tein Ra's (00R101)
i think this is what happens when you put RACE suspension on a STREET car
Old Jun 24, 2003 | 11:19 AM
ITRbroham's Avatar
shit post warrior
I would call Tein first before trying anything yourself!
If you damage the coilovers by trying to repair it yourself, then it's possible they might give you a hard time if you send them in to be repaired.
Just a thought.
Old Jun 24, 2003 | 11:31 AM
RagingAngel's Avatar
Default Re: Seized Tein Ra's (ITRbroham)
some people just take the weather or the climate we live in for granted.
In Vancouver we must have some of the mildest weather in Canada but the winters, as well as the rain..... whatever it's just crap on parts sometimes.
Agreed with Steady that a race damper needs to have a little more maintenance than a standard damper with regards to keeping it clean so you don't have these kind of headaches.
Hasn't ANYBODY heard of Anti-Seize???
I could move to So.Cali Arizona and I'd still use this stuff!!!
Old Jun 24, 2003 | 01:35 PM
SkyeC's Avatar
Boba Connoisseur
25 Year Member
Next time make sure you clean them off regularly and spray some WD40 on them every month or so. I even do that with my GCs and their perch is about 600x better than that locking collar bullshit.
Old Jun 24, 2003 | 08:11 PM
AW's Avatar
AW
Default Re: Seized Tein Ra's (SkyeC)
I had the same problem with my HA's. We tried the heat and what finally happened is that the rings broke in half. I had to buy replacement rings for all four shocks. Just keep them clean and you should be fine....
