tin foil around o2 sensor?
Old Jun 23, 2003 | 01:07 PM
SOHC_MShue's Avatar
Default tin foil around o2 sensor?
who has tried this with their test pipe? Does it actually work and how long will it last? Do you just take out the o2 sensor, plug up the o2 bung, wrap the sensor in tin foil, and then tape it somewhere else?
Old Jun 23, 2003 | 01:09 PM
poison's Avatar
Default Re: tin foil around o2 sensor? (SOHC_MShue)
I've heard of this working to remove the secondary o2 sensor and not throw the code. A few of my friends who installed this with a DC Header has gotten it to work.
Old Jun 23, 2003 | 04:25 PM
SOHC_MShue's Avatar
Default Re: tin foil around o2 sensor? (poison)
have they had any problems with it at all? How does the tin foil work and won't it be bad if the sensor isn't reading anything?
Old Jun 23, 2003 | 05:06 PM
SOHC_MShue's Avatar
ttt
Old Jun 23, 2003 | 05:09 PM
genetsang's Avatar
hmm would you have to wrap the entire o2 sensor in the foil? as in.. including the tip of the sensor? so the incoming flow doesnt touch the tip when it is screwed back in the bung.
Old Jun 23, 2003 | 05:24 PM
SOHC_MShue's Avatar
Default Re: tin foil around o2 sensor? (genetsang)
should i even screw it back into the bung or just ziptie it somewhere under the car? If i'm not using the bung what could i use to plug it up since there wouldn't be a sensor in there?
Old Jun 23, 2003 | 05:30 PM
genetsang's Avatar
dude i dont even know haha. i wanted to install my test pipe. but i didnt want to have a CEL.. but i was told, just like you, to wrap the sucker up with tin foil.... my guess is to plug it back into the bung... i mean on my test pipe there is a bung for the o2 sensor.... assuming that, thats what it is used for.
Old Jun 23, 2003 | 07:11 PM
SOHC_MShue's Avatar
yea well i heard a bunch of other people say they didn't put it in the bung and just ziptied it somewhere. I am wondering what i should plug the bung up with though.
98savage
Jun 15, 2007 09:35 PM
TypeR864
Sep 22, 2005 08:23 AM
gelok
Jul 22, 2003 09:47 PM
JoshRambo
May 15, 2003 01:09 PM
