2 Pics! Secondary butterfies / IAB! Which one is open? Which one is closed?
Old Jun 23, 2003 | 09:39 AM
Fuster_Cluck's Avatar
Default 2 Pics! Secondary butterfies / IAB! Which one is open? Which one is closed?
My secondaries are not opening at 6k like they should be if everything was wired correctly. I was told that when the secondaries open the rod on this diaphram will go down.
Just went out and took a look and with the motor off the rod is DOWN:
When I rotate the clip around the rod moves up toward the hood / shortening the rod:
When the secondaries kick in at 6k should the rod be down like in the top pic or up as in the second pic?
93 Cx
98 GSR (usdm)
OBD1 p72 ECU
Thanks!
Old Jun 23, 2003 | 11:21 AM
Katman's Avatar
Default Re: 2 Pics! Secondary butterfies / IAB! Which one is open? Which one is closed? (Hybrid93Hatch)
I believe you were misinformed.
ROD DOWN = closed 2ndaries
ROD UP = opened 2ndaries
Old Jun 23, 2003 | 02:49 PM
Lord Helmet's Avatar
Default Re: 2 Pics! Secondary butterfies / IAB! Which one is open? Which one is closed? (Katman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Katman &raquo;</TD></TR><TR><TD CLASS="quote">I believe you were misinformed.
ROD UP = opened 2ndaries</TD></TR></TABLE>
I concur
Old Jun 23, 2003 | 05:55 PM
shonnys92si's Avatar
Default Re: 2 Pics! Secondary butterfies / IAB! Which one is open? Which one is closed? (sleeperciv)
i have the same problem. i have 92 si with 94 jdm gsr b18c, i reeved it up to 6k and the little stick did not go down. all i remenber doing when i did my swap was move tha A20 to A17, i dont remenber moving a black wire. and give it 12volts or something like that . what else do i need to do to besides moving the a20 to a17. thanx
Old Jun 23, 2003 | 09:00 PM
1titesol's Avatar
O.K. the diaphram gets vaccum at idle, the diaphram raises the rod. The secondaries are closed for high torque at low rpms. Around 6k the diaphram loses vaccum from your wired selinoid, therefore droppin the rod to open the secondaries for maximum horsepower at high rpms. I've personally taken one apart an the secondaries were open. When i pressed the rod up in the diaphram, they closed.
Modified by 1titesol at 6:32 AM 6/24/2003
Old Jun 24, 2003 | 05:25 AM
CHEETAH's Avatar
bottom pic should be at idle (lever is up) ... at 5750rpm it comes down ... the black box connects to a17
greg
boostedcivicsir
Welding / Fabrication
Jan 29, 2006 11:46 AM
Hybrid ctr
Honda S2000
Mar 29, 2003 09:53 PM
boosted3g
Jan 15, 2003 04:48 PM
sicivic
Oct 1, 2002 08:15 PM
