Help with removing metal O in Hub so axles wont bind
Old Jun 23, 2003 | 07:28 AM
Blaze45's Avatar
Brrraaaap!
Default Help with removing metal O in Hub so axles wont bind
Hasports site says to remove the metal spacer, how do you get it out? I tried with a screwdriver, it didnt cut it, any help would be great!
Blaze
Old Jun 23, 2003 | 08:15 AM
Moe's Avatar
Moe
Default Re: Help with removing metal O in Hub so axles wont bind (Blaze45)
What metal ring, if your talkin about the snap or set ring, at the end of the spindled end of the axel. That has to stay there it helps the axel from popping out. Heres a link to a pic, so you can help better explain it.
http://www.hondaautomotivepart...82%29
Old Jun 23, 2003 | 10:25 AM
Blaze45's Avatar
Brrraaaap!
Default Re: Help with removing metal O in Hub so axles wont bind (Moe)
http://www.hasport.com/News/Ar...s.htm
they show a picture of it being removed from the hub, not the axle. It is a metal ring.
Blaze
Old Jun 23, 2003 | 10:28 AM
Blaze45's Avatar
Brrraaaap!
I dont know if my CRX even has this ring.
Old Jun 23, 2003 | 01:00 PM
Blaze45's Avatar
Brrraaaap!
Anyone?
Old Jun 23, 2003 | 08:18 PM
Blaze45's Avatar
Brrraaaap!
No one knows?
Old Jun 23, 2003 | 08:29 PM
Moe's Avatar
Moe
Ohh i have never noticed that... im guessing that the spindled end will sit against that, after you put your spindled end through the hub.
Fawk you learn something new everyday, when in doubt, get a hammer. With a older car like that a hammer may very well be your best friend.
Old Jun 23, 2003 | 08:53 PM
Neukin's Avatar
i didnt take it out... if you put the nut on with the axle like that it locks up and wont turn, i bought some large washers and stuck 1 or 2 on to keep from hanging up and not turning. i used 90 integra axles i think. b16a in crx by the way i run 10psi on the engien and they havent broke or whatever yet so i think it will work for you.
Old Jun 23, 2003 | 10:09 PM
Blaze45's Avatar
Brrraaaap!
Default Re: Help with removing metal O in Hub so axles wont bind (toyosupr)
How do I get it out ( the metal O spacer) ? So your saying once you removed it, your axle would lock up?
Blaze
Old Jun 24, 2003 | 12:02 AM
1st-hybrid's Avatar
They should be fairly easy to remove. Try using a small pry bar to catch the lip, then just pop them off. if they're heavily rusted spray a little break free on there and let them sit for a couple of minutes, then pop them off as described above.
Either way they should come off easily. Mine came out with no problems.
Old Jun 24, 2003 | 01:41 AM
irev210's Avatar
Default Re: Help with removing metal O in Hub so axles wont bind (1st-hybrid)
I use HASport everything and i never removed those, I have no problems at all w/ axles.
Old Jun 24, 2003 | 04:30 AM
Neukin's Avatar
Default Re: Help with removing metal O in Hub so axles wont bind (irev210)
i never removed the "metal o in hub" i just put axles on and it locked up a bit so i put a few washers on the axle shaft and slid into hub.
Old Jun 24, 2003 | 08:04 AM
Blaze45's Avatar
Brrraaaap!
Ah, I see. thanks.
Blaze
Randysi
13
Jun 29, 2011 07:58 PM
LSej1
Jul 22, 2010 02:04 PM
KING_LIAN
Oct 3, 2007 07:35 AM
averyvm
Nov 23, 2006 09:28 PM
agp1183
13
Aug 1, 2005 04:10 PM
