Cam installation(car runs worse)
Old Jun 23, 2003 | 06:29 AM
sicklexus1's Avatar
Default Cam installation(car runs worse)
I have a 01 ITR and have Aem cold air intake, DC jdm headers, Skunk 2 stage II cams, gears, retainers, and valve springs, along with a vafc. Before when I had only intake and headers I ran a 14.87 with the elevation at 3900 ft. I have not had a chance to tune it yet, but I wanted to know where I was at so I raced a friend of mine. He has a civic hb. His best time was a 14.9. I figured since I installed this stuff it should still should run a little better, but it turns out I got killed like by 3 cars. Is this normal. Would tuning make a 5-7 car difference?
Bonnie
Old Jun 23, 2003 | 06:33 AM
NSX Bob's Avatar
New User
Default Re: Cam installation(car runs worse) (bonnieornelas)
There are a lot of variables that could describe your "problem," but the bottom line is that you do need to tune the car to get the most out of what you have put into it.
Old Jun 23, 2003 | 06:35 AM
Ferrell's Avatar
Default Re: Cam installation(car runs worse) (Type R Bob)
tuning is the key.
Old Jun 23, 2003 | 07:01 AM
00MRSi's Avatar
Default Re: Cam installation(car runs worse) (Ferrell)
Unfortunately, cams are not a "drop in and go" mod. I'd definetely try and get to the dyno asap.
Old Jun 23, 2003 | 07:18 AM
STOLEN - ITR 98-0652's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bonnieornelas &raquo;</TD></TR><TR><TD CLASS="quote">I have not had a chance to tune it yet.</TD></TR></TABLE>
Therein lies the problem, eh?
Old Jun 23, 2003 | 07:26 AM
1GreyTeg's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bonnieornelas &raquo;</TD></TR><TR><TD CLASS="quote"> I have not had a chance to tune it yet, but I raced a friend of mine.
Bonnie </TD></TR></TABLE>
No tuning and you're "Racing" it already.
As well, your results may not be related to the car/cams alone but rather the driver.
Old Jun 23, 2003 | 08:03 AM
VTHokie's Avatar
Default Re: Cam installation(car runs worse) (1GreyTeg)
Same thing happened to my friends si when he put in his stage 1 cams. Here is the before and after MUSTANG dyno. Notice the huge difference after tuning, before his car would just die in VTEC.
Skunks are not "DROP IN AND GO" cams. Get those things tuned, and you'll have better luck.
Old Jun 23, 2003 | 08:44 AM
b18c-rDC2's Avatar
Default Re: Cam installation(car runs worse) (VTHokie)
I have a strong inclination that you still have oem pistons in which case your compression is 10:6, which is not nearly enough compression to utilize the potential of the skunk2 stage 2 cams, in fact you would have been better off going with skunk2 stage 1 cams with compression that low. Im running skunk2 stage 2's, though my compression is around 13:1...hope this helps you understand why the car may not be performing as you initially thought it would.
Old Jun 23, 2003 | 08:59 AM
Ex-ITR5874's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bonnieornelas &raquo;</TD></TR><TR><TD CLASS="quote">I have a 01 ITR and have Aem cold air intake, DC jdm headers, Skunk 2 stage II cams, gears, retainers, and valve springs, along with a vafc. Before when I had only intake and headers I ran a 14.87 with the elevation at 3900 ft. I have not had a chance to tune it yet, but I wanted to know where I was at so I raced a friend of mine. He has a civic hb. His best time was a 14.9. I figured since I installed this stuff it should still should run a little better, but it turns out I got killed like by 3 cars. Is this normal. Would tuning make a 5-7 car difference?
It takes skill to tune a cam setup so that it can kill a strong and well optimized stock engine...
I kicked that cam-thing to the moon and searched for a strong stock engine until I found one...better for peace of mind anyway.
8_6 luder
Jan 20, 2007 07:27 PM
ukcrxvt
Aug 8, 2005 12:55 PM
Integ03
Mar 5, 2004 01:10 AM
sicklexus1
May 13, 2003 10:06 AM
Red98GSR
Feb 22, 2002 06:08 PM
