a way to get boost with no turbo or super
Old Jul 24, 2001 | 03:11 PM
Strider Turbo's Avatar
Default a way to get boost with no turbo or super
http://www.esurbo.com/
This sounds cool but strange at the same time. Tell me what you guys think about it???
Old Jul 24, 2001 | 04:26 PM
dustin's Avatar
Default Re: a way to get boost with no turbo or super (Strider Turbo)
Sounds like a load of BS to me. I am not sure what sort of engineering experience that guy THINKS he has, but he is wrong in almost every scenario from a technical perspective.. Heh.
I especially like the part where he says you can run leaner A/F ratios because the engine has the "surbo" helping it. He says the extra air in the combustion chamber helps push the piston down because it is pressurized air.. Sure buddy.
And apparently you get on the throttle, and then let off... repeatedly.. to build "boost" heheh. Sounds like an effective way to accelerate.
Some of my favorite quotes:
The purpose of this guage here is open the throttle wide enough to activate the Surbo, but not too wide that there is retardation due to excessive fuel.
I hate when I get retardation due to excessive fuel. Damn that retardation!
Instead of more air and more fuel for more power, the Surbo system uses air pressure, less fuel and mechanical feedback.
I have had it wrong all along... I thought increasing fuel/air and eliminating friction/increasing efficency were the two ways to make power. Apparently using less fuel is the way to go.
When you become familiar with the system, it will be very easy to extract smooth surging and also from 2000 rpm especially in the low gears.
Is smooth surging a contradiction in terms?
In fact, there is also less combustion heat due to a smaller fuel input and greater cooling from increased airflow. We have never had a claim for engine damage.
Apparently leaning out the mixture is the best way to cool the cylinders...I see.
For racing purposes, especially sprints, since the Surbo adds a thousand rpm to most cars at the peak, rev limiters may be taken off to take advantage of the higher peak. This is also in view of the fact that fuel-cutoff slows the car significantly when it occurs. It may also be fun to have a big rpm meter right in front of you, on top of the dashboard as the rpm will climb very quickly. There's no time to look down. Like in those drag cars!
I hate when stupid, uneducated manufacturers install those pesky rev limiters! Rev limiters begone!
and the Elantra could hit red line in 1st gear with only 1/4 accelerator travel
Impressive.
Higher octanes are used so that your car will have less pinking, that means firing before the pistons are properly near the top of their travel. With the Surbo on, the pinking tendency is lessened due to a halved fuel input, the pushing done by extra air which is not so combustible spontaneously as fuel. You can therefore switch to lower octanes to save money.
Summary: Since you are using less fuel and leaning out, the chances of detonation are much lower. Since air does not burn as well as fuel does, you are set!
Yes, your car will accelerate like a light turbo car after installing the Surbo, with strong thrust forces like that of commercial aircraft takeoffs, timed at 8 seconds from standstill to 100kph
If my commercial airplane accelerates that slowly, I am in serious trouble. I guess my GSR accelerates at the speed of light then.
The extra, unburnt air provided by the Surbo will turn the pistons for free as it is pressurised. Usually, it is good to provide an early aircharge as it is so much easier to put in fuel quickly by pushing on the accelerator than to put in air, due to the air filter's resistance. So, the Surbo is useful as the extra air pull force overcomes filtration losses.
Perhaps we can look at it another way. An unassisted engine will do well to have the ideal fuel-air ratio. However, when we go downhill, we can press less on the accelerator (less fuel) and yet have the same engine speed (same amount of air). It is because the engine is under the assistance of gravity. Likewise, when pushed by the Surbo system, the engine can do the same work with a lower fuel-air ratio.
Umm. Yeah.
Dustin
Old Jul 24, 2001 | 04:37 PM
mike's Avatar
H-T Order of Merit
Default Re: a way to get boost with no turbo or super (dustin)
I just read the "How it Works" section and that seems like a really bad idea.
Mike
Old Jul 24, 2001 | 04:55 PM
Seraph0's Avatar
Default Re: a way to get boost with no turbo or super (mike)
What a crock of BS!!!
"Surbo"!!! !!!!!!!!
Old Jul 24, 2001 | 08:04 PM
falcongsr's Avatar
What is this crap?
Default Re: a way to get boost with no turbo or super (MarkC)
I dunno, smooth surging sounds pretty cool!
Old Jul 25, 2001 | 08:55 AM
GSR_Dude's Avatar
sweeeeeeeet........retardation, smoother surging, better detonation, less fuel, more power !!! SURBO ALL THE WAY !!!!!! I think I'm a lot dumber for reading this....
Old Jul 25, 2001 | 09:18 AM
dbman96's Avatar
New User
Default Re: a way to get boost with no turbo or super (GSR_Dude)
Once again, I think we know exactly who all this guys base are belong to.
Maybe he has less retardation and smoother surging when someone set up him the bomb... er... surbo.
Old Jul 25, 2001 | 11:31 AM
bigTom's Avatar
i am now officially dumber
Old Jul 25, 2001 | 11:38 AM
apexii's Avatar
Default Re: a way to get boost with no turbo or super (dbman96)
hehehe...
I really enjoyed Dustins review though..
apexii- who is now an official surbo dealer for NA.
Old Jul 25, 2001 | 11:45 AM
dbman96's Avatar
New User
I keep trying to read that page over again and it's giving me a headache.
Old Jul 25, 2001 | 11:49 AM
Rain_man's Avatar
New User
Default Re: a way to get boost with no turbo or super (apexii)
Owwww.... my head hurts, too much thinking.
Old Jul 25, 2001 | 11:51 AM
VaporTrail's Avatar
New User
You know, there was a time in my life I might have bought the surbo - when I was in third grade!
Old Jul 25, 2001 | 01:47 PM
civicguy's Avatar
that guy explains in reverse,thats is problem
Old Jul 25, 2001 | 01:55 PM
leechungsr's Avatar
The worst part is that there are morons buying this.
Once, I saw a Mustang GT parked with fat *** SPIRALMAX stickers on his car...his exhaust tips had those pinwheel looking things..Surbo must be much more effective than a Spiralmax..
Old Jul 25, 2001 | 04:32 PM
You go HEH. I was thinking that this thing was kinda wierd. Would love to give it a review like you , but I don't know enough to do that. Althought I kinda thought it was weird that you were suposed to be running "4.3psi" and the car doesn't go into limp mode? Wouldn't the Computer freak out??
Sorry for all the headaches guys got get some asprin.
There is only one way to the Darkside!
Old Jul 25, 2001 | 10:41 PM
VaporTrail's Avatar
New User
You know, did anyone notice that there were diesel applications on there? If so, that would explain a lot of it.
Old Jul 25, 2001 | 10:47 PM
dustin's Avatar
Default Re: a way to get boost with no turbo or super (VaporTrail)
I would still like to understand how he claims to compress air, since his explanation did not make sense nor follow the laws of physics.
Old Jul 26, 2001 | 07:13 AM
dbman96's Avatar
New User
Yeah did you notice that he claims that "high velocity" equates to "high pressure"? I dunno what fluid mechanics course he took.
Of course, if we limit ourselves to following the laws of physics, how are we ever going to break the 2.4 second quarter mile?
Old Apr 17, 2003 | 05:38 PM
dustin's Avatar
This is the coolest thread ever. Time to revive it.
Old Apr 17, 2003 | 06:42 PM
racerxadam's Avatar
sounds like an "interesting" engineering concept. too bad http://www.esurbo.com seems to not exist anymore. at least my browser won't load it
Old Apr 17, 2003 | 06:44 PM
lazerus's Avatar
most e-turbo crap is JUNK. here's the real deal.
http://waw.wardsauto.com/ar/au...ctric
Brad
shermanyang's Avatar
Default Re: a way to get boost with no turbo or super (ek9t)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ek9t &raquo;</TD></TR><TR><TD CLASS="quote">i am now officially dumber</TD></TR></TABLE>
lol...ummm....ddduuuuhhhhhhhh....
Old Apr 17, 2003 | 06:59 PM
Teg4e's Avatar
Default Re: a way to get boost with no turbo or super (shermanyang)
damn, i missed this thread back in july....sounds funny
Old Apr 17, 2003 | 07:45 PM
b16ahybrid's Avatar
&lt;BLOCKQUOTE&gt;quote:&lt;HR&gt;The purpose of this guage here is open the throttle wide enough to activate the Surbo, but not too wide that there is retardation due to excessive fuel. &lt;HR&gt;&lt;/BLOCKQUOTE&gt;
&lt;BLOCKQUOTE&gt;quote:&lt;HR&gt;Instead of more air and more fuel for more power, the Surbo system uses air pressure, less fuel and mechanical feedback.&lt;HR&gt;&lt;/BLOCKQUOTE&gt;
&lt;BLOCKQUOTE&gt;quote:&lt;HR&gt;When you become familiar with the system, it will be very easy to extract smooth surging and also from 2000 rpm especially in the low gears.&lt;HR&gt;&lt;/BLOCKQUOTE&gt;
&lt;BLOCKQUOTE&gt;quote:&lt;HR&gt;In fact, there is also less combustion heat due to a smaller fuel input and greater cooling from increased airflow. We have never had a claim for engine damage.&lt;HR&gt;&lt;/BLOCKQUOTE&gt;
&lt;BLOCKQUOTE&gt;quote:&lt;HR&gt;For racing purposes, especially sprints, since the Surbo adds a thousand rpm to most cars at the peak, rev limiters may be taken off to take advantage of the higher peak. This is also in view of the fact that fuel-cutoff slows the car significantly when it occurs. It may also be fun to have a big rpm meter right in front of you, on top of the dashboard as the rpm will climb very quickly. There's no time to look down. Like in those drag cars!&lt;HR&gt;&lt;/BLOCKQUOTE&gt;
&lt;BLOCKQUOTE&gt;quote:&lt;HR&gt;and the Elantra could hit red line in 1st gear with only 1/4 accelerator travel&lt;HR&gt;&lt;/BLOCKQUOTE&gt;
Impressive.
&lt;BLOCKQUOTE&gt;quote:&lt;HR&gt;Higher octanes are used so that your car will have less pinking, that means firing before the pistons are properly near the top of their travel. With the Surbo on, the pinking tendency is lessened due to a halved fuel input, the pushing done by extra air which is not so combustible spontaneously as fuel. You can therefore switch to lower octanes to save money. &lt;HR&gt;&lt;/BLOCKQUOTE&gt;
&lt;BLOCKQUOTE&gt;quote:&lt;HR&gt;Yes, your car will accelerate like a light turbo car after installing the Surbo, with strong thrust forces like that of commercial aircraft takeoffs, timed at 8 seconds from standstill to 100kph&lt;HR&gt;&lt;/BLOCKQUOTE&gt;
&lt;BLOCKQUOTE&gt;quote:&lt;HR&gt;The extra, unburnt air provided by the Surbo will turn the pistons for free as it is pressurised. Usually, it is good to provide an early aircharge as it is so much easier to put in fuel quickly by pushing on the accelerator than to put in air, due to the air filter's resistance. So, the Surbo is useful as the extra air pull force overcomes filtration losses.
Umm. Yeah.
Dustin
Thanks for the great laughs...
Old Apr 17, 2003 | 07:55 PM
MiraiZ's Avatar
link not working...
