ls motor into a dx hatch
just plug new harness into stock harness where dx ecu is and motor to stock harness and change axles to lS and radiator and brake master cylinder thats it? is that all?
just plug motor into engine bay and your done
you dont need to change the harness by your ecu . infact you dont need to change any harness if your car is 92-95 . depends on the year of your motor you will need to rewire the distributer if its obd2 plugs . other than that change axels , linkage , ecu and radiator hoses
if your LS is 95 below it OBD1 if its 96 above its OBD2 keep ur originall harness and injectors and blah blah and get you a OBD 2 -OBD1 harness better & cheaper
y better cause naturally OBD2 (96+) is newer model then OBD1 (95-)
cheaper in the long run cause you wouldn't have to miss match parts
why would you change the brake master cylinder?? no need for that
just swap, mount, plug, and pray that nothing further delays the swap
