AC box behind Glove box
Old Jun 22, 2003 | 09:08 PM
xrtdac
Guest
Posts: n/a
Default AC box behind Glove box
I was wondering if anyone can help me find out how to take that heavy *** thing out from underneath my dash. I have no more AC cause I went turbo and I do realize what I lost on the hot days but also realize the weight savings as well as the breathing room for coolin the engine and turbo stuff. I searched H-T and I couldn't find anything. PICS would be also hugely appreciated. thanks.
Old Jun 22, 2003 | 11:40 PM
RCautoworks's Avatar
Default Re: AC box behind Glove box (xrtdac)
What car are you taking it out off ? Usually there are like 3 screws holding it on. Crawl under there and take a peek around.
Old Jun 22, 2003 | 11:44 PM
Default Re: AC box behind Glove box (90blackcrx)
Here is a pic to help you out
Old Jun 23, 2003 | 08:55 AM
xrtdac
Guest
Posts: n/a
Its a 1997 Integra LS
Old Jun 23, 2003 | 06:53 PM
xrtdac
Guest
Posts: n/a
is that just right behind the glove box?? Is there anything else I need to do besides just pulling it out?
Modified by xrtdac at 12:07 AM 6/24/2003
Old Jun 23, 2003 | 11:07 PM
xrtdac
Guest
Posts: n/a
hello?
Old Jun 24, 2003 | 06:27 AM
averageJoe's Avatar
Default Re: (xrtdac)
yep, thats all you are going to have to take out. However, you must take out the coils (or whatever its called), and put the surrounding plastic back in the car as an empty shell. If you dont do this, your fan will not blow out your vents in the dash
Its easy to take out, just those few screws and an little wedging
Joe
Old Jun 24, 2003 | 02:17 PM
xrtdac
Guest
Posts: n/a
Default Re: (averageJoe)
can you explain that a tad further? There are coils or something? I thought you could jsut take that box out and thats all. Just leave it at that?
Old Jun 24, 2003 | 03:23 PM
averageJoe's Avatar
the evaporaor has something like a thick radiator that is surrouned by freon tubing. This is how you get cold air from the AC. the blower blows normal air through the evaporator and cools it (same way a radiator works, but much colder).
If you take out the entire evaporator, the blower will just blow into the passenger side foot well. If you just take out the coils and tubing (it is surrounded by styrophome) and put the black plastic part back in the car, the blower will be able to blow to the vents, because the air is routed by the plastic piece of the evaporator
Old Jun 24, 2003 | 07:40 PM
xrtdac
Guest
Posts: n/a
thanks a bunch. so I jsut gut the black plastic box and then put that back in empty correct?
Old Jun 25, 2003 | 07:32 PM
blueeg's Avatar
thats what he said.
Old Jun 25, 2003 | 08:46 PM
xrtdac
Guest
Posts: n/a
Spank you very little. I mean thanks.
Choy
Mar 28, 2010 01:56 PM
grey_ghost
Sep 21, 2007 09:53 PM
The Hooligan
May 22, 2005 12:00 PM
HybridHatchC1
Apr 30, 2004 05:33 AM
Art Vandeleigh
Feb 14, 2002 09:16 PM
