ECU code 42
Old Jun 22, 2003 | 05:27 PM
busterray's Avatar
Default ECU code 42
I have an 86 CRX Si, 1.5 that has been fuel fouling the plugs. Finally figured out today how to check the ECU codes. The code it is giving is 42: engine coolant temp sensor. Will this sensor make it foul the plugs? Sometimes it will start and run like a champ, other times it will run like shimp. Also, the PGM-FI light on the dash is on. What does this mean?
Thanks guys.
Old Jun 23, 2003 | 12:03 PM
JimBlake's Avatar
Default Re: ECU code 42 (busterray)
If the ECT is bad, it might run rich all the time if the ECU thinks the engine is cold. If the ECT failed in a way that makes the ECU think it's hot, then the car wouldn't start real easily.
lakahang
Dec 19, 2009 03:23 PM
juanchoenuncrx
11
Oct 17, 2007 07:30 AM
initialR
Jan 10, 2005 10:06 AM
kim_2_da_chee
May 30, 2003 06:18 PM
