Calibrating Sensors
Old Jun 22, 2003 | 03:03 PM
ion_four's Avatar
Default Calibrating Sensors
I couldn't find anything in the archives, so...
I am planning on buying some VDO senders (fuel pressure, oil pressure, oil temp and water temp) however, I am going to make my own led bar-graph gauges with warning lights (possibly buzzers?). My main questions is; what are the ranges of temps/pressures these senders will see? Fuel should be between 30-55psi (with boost), but I only have a vague idea about the others.
I just want to get an idea of what I should scale the gauges to after I calibrate them with an air compressor/boiling water, etc. respectively...
Thanks in advance.
Old Jun 22, 2003 | 04:47 PM
Hondaaccordvtec's Avatar
Default Re: Calibrating Sensors (ion_four)
The best suggestion I have is contact VDO and see what they say are the limits of those senders you have.
Old Jun 23, 2003 | 08:46 AM
ion_four's Avatar
Default Re: Calibrating Sensors (Hondaaccordvtec)
Thanks, but I'm mainly wondering what some normal temperature/pressure ranges are for a d16z6...particularly fuel, oil, coolant. The car is running less than 10psi of boost (if that needs to be taken into account).
fishieman
Dec 10, 2008 10:43 PM
lilshady6796
Nov 12, 2008 10:55 AM
Pure Sol
Nov 24, 2005 01:29 PM
Boostless97Lude
Jun 18, 2003 08:42 AM
E Swift
Jun 5, 2002 08:34 PM
