Need help with 91 Accord
Old Jun 22, 2003 | 01:31 PM
Dave R's Avatar
Default Need help with 91 Accord
I have a 91 Accord coupe and the driver's side window is coming out of the track. It seems to be a bolt like connector that just keeps it aligned. Does anybody know if I can get this part, and if so, is it a easy fix?
Old Jun 22, 2003 | 02:45 PM
87_accord_lx's Avatar
Default Re: Need help with 91 Accord (Dave R)
my 944 turbo had the same problem,just take the door panel off and it schould be a easy fix. my 944 was easy cause there is alot of room to move your hands around.
scott
Old Jun 22, 2003 | 07:12 PM
RUBZERK's Avatar
put the window back on track & spray the track with silicon spray.
the track has a thin layer of felt like fibers that wear out. when that wears out the window catches on the rubber causing it to jump off track & like in your case.
cheap way is to use the silicon spray. just use 2x a year
Old Jun 23, 2003 | 03:51 AM
SearchBeforeUPost!'s Avatar
Default Re: Need help with 91 Accord (RUBZERK)
what kind of silicone spray do you use? and will it f up the tint?
Old Jun 23, 2003 | 07:58 AM
AccordDriver92's Avatar
yea... you have to take the door panel off and so forth.
Jared.Mann
Feb 24, 2017 05:57 PM
Brizzal02
Jan 5, 2010 02:51 PM
inaety
Nov 3, 2009 08:20 PM
renegadez7o7
Jan 7, 2006 09:16 PM
AccordCD5
Jun 8, 2004 05:30 AM
