4 wire 02 sensor
Old Jun 22, 2003 | 06:48 AM
Audipwr1's Avatar
Default 4 wire 02 sensor
2 whites
1 grey
1 black
what is what?
the two white wires have about 6.7 ohms resistance
Modified by Audipwr1 at 11:55 PM 6/22/2003
Old Jun 22, 2003 | 07:01 AM
3gdude's Avatar
Default Re: 4 wire 02 sensor (Audipwr1)
What exactly are you trying to find out?? It's easier to find out what they are by seeing what color wire they connect to on the harness side. These are the colors given in a wiring diagram....3gdude
Old Jun 22, 2003 | 07:05 AM
Audipwr1's Avatar
Default Re: 4 wire 02 sensor (3gdude)
its a gm 02 sensor... that i am splicing into an obd1 system that has no engine bay harness
Old Jun 22, 2003 | 07:22 AM
3gdude's Avatar
Working from memory, I think the two gray ones are for the heater, verify with ohmmeter ( 20-80 OHMS)....the white one is the sensor signal, and the black is the ground for the sensor signal. To be on the safe side, just hook black to ground, then monitor voltage on the white wire. Voltage should vary between .1 and .9 volts, after a 5 minute warm up (as the heater is not yet hooked up)....that help any??...3gdude
Old Jun 22, 2003 | 11:24 AM
Audipwr1's Avatar
what wire should get the 12v?
both the whites?
the black the ground
the grey the signal?
Old Jun 22, 2003 | 02:55 PM
Audipwr1's Avatar
up with new info
Old Jun 22, 2003 | 06:17 PM
Audipwr1's Avatar
eh
Old Jun 22, 2003 | 06:28 PM
poison's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Audipwr1 &raquo;</TD></TR><TR><TD CLASS="quote">2 whites
1 grey
1 black
what is what?
Gray-&gt; WHT-&gt; D14 (O2 input)
Black -&gt; GRN/WHT -&gt; which is spliced with the IAT, but GRN/WHT is the sensor ground doing to D22. You can splice it with the GRN/WHT wire at the IAT though.
White -&gt; YEL/BLK -&gt; Sensor positive which goes to the power junction harness, but this goes to A25 or B1.
White -&gt; ORG/BLK -&gt; to A6 which is Heater Control.
HTH
Old Jun 23, 2003 | 01:00 PM
Audipwr1's Avatar
Default Re: 4 wire 02 sensor (poison)
you are god
Sereth
Honda Civic (2001 - 2005)
Aug 23, 2017 01:12 AM
bluez6
Jul 15, 2006 11:41 PM
downest
May 15, 2006 08:19 PM
V3locity
Jul 24, 2004 06:32 PM
